Battery for Axial SCX10 RTR Honcho
+5
9 posters
Hi all,
Want to get some batts for my incoming RTR Honcho Probably asked a million times, but can't seem to find a thread on this topic.
What is the most appropriate Lipos for RTR Honcho? 2S / 3S ? and min. how many mAH and Cs are necessary? Am considering to go S'wan to take a look, but if there are other locations to explore hope to get some hints here too.
I know answer probably also depends on how long or how fast I wanna chiong but just considering some typical trailing on weekends and what most SGcrawlers are using.
Paiseh if there is already a thread started on this, please re-direct me, thanks!!
RCGolf- Crawler
Re: Battery for Axial SCX10 RTR Honcho
honcho stock esc can only run on 2s max.
a 5000mah can last u the whole trail and the Cs no need that high if just trailing.
and if you can wait, order from hobbyking, much much cheaper than local bro.
Ya hobbyking shipping ard 1 week only
Haha if buying 1 or 2 pcs lhs can la try jet hobby but if u buying a lot hobbyking the best to shop
Went to check out the prices at HobbyKing.. indeed very attractive prices !!
Thanks guys!
Thanks guys!
RCGolf- Crawler
Don' t forget that you also need a suitable charger, and that both ESC and the battery have the right connector!
Lipo buzzer to....
Harakiri- Boss
laneboysrc wrote:Don' t forget that you also need a suitable charger, and that both ESC and the battery have the right connector!
Harakiri wrote:Lipo buzzer to....
Thanks for the headsup. Yup, got my old Hyperion Lipo charger and a low voltage alarm on standby. Once kit arrives, think should be more or less ready to roll
RCGolf- Crawler
alright man!! looking forward to see the new truck at the trails!
me too , still waiting for my servo from hobbyking ..... once ready we can roll together ....
kelvintan_hc- Crawler
Yeah! Another Honcho owner!
quest though: Why do u need buzzer if ESC has LVC (low voltage cutoff)? Or what is LVC for then? confused
DWJL511- Crawler
DWJL511 wrote:quest though: Why do u need buzzer if ESC has LVC (low voltage cutoff)? Or what is LVC for then? confused
Indeed, Axial AE-2 ESC shipped with current Honcho's has LiPo cut-off, so buzzer is strictly speaking not needed.
Does it? Anyone know at what voltage does the axial ESC cut-off the Lipo?
RCGolf- Crawler
I read it in my manual.
Tech Notes from TH:
NOTES FROM OUR TECH DEPARTMENT
This is the AE-2 Forward/Reverse Esc with Drag Brake.
FEATURES:
Forward, Reverse and Drag Brake Function
Preinstalled motor leads and Kyosho type battery connector
Universal receiver connector
Programmable using the Castle Creations Castle
LiPo cutoff set up from factory
INCLUDES: AE-2 Forward/Reverse ESC with Drag Brake Instruction sheet
REQUIRES: Installation on the Rock Crawler
SPECS:
Input Voltage: 6 cell Nickel/2S Lipo
Dimensions: 1.7 x 1.24" (43.2 x 34.5)
Weight: 1.6oz (45g)
Motor: 19T or greater On-Resistance
FET: 0.0018ohms
Rated/Peak Current: 106A
Peak Braking Current: 106A
BEC Voltage/A: DC 5V/2A
PWM Frequency: 6K Hertz [b]
Tech Notes from TH:
FEATURES:
SPECS:
Weight: 1.6oz (45g)
FET: 0.0018ohms
DWJL511- Crawler
