Slow's Jeep JK in Singapore
+3
7 posters
My Next Build ..
Jeep JK
JK hard Body from NEW BRIGHT
Chassis from RCMODELEX
Jeep JK
Re: Slow's Jeep JK in Singapore
So these are my JK builders... ..
Size of the JK Body
Wah, the paint job so shiny. Slow you got so many ppl to help you har.
Cutting out the Front Plastic Bumper.. .
Fitted to the Chassis
Mounting the Body the Chassis
Making 4 body mounting point to the Chassis.
Rear using 2 x 55mm links
Front View
Greasing the Axles with lots of Marine Grease.
4-links set-up
Rear Links
Top using 2 x 70mm links
Bottom using 101mm High Clearance Links
Front Links
Top using2 x 60mm links + 4 x 3mm nuts ( 66mm per links )
Bottom using 94mm High Clearance Links + 2mm each link ( 96mm per links )
Shrink Wrap all the links
Rear Links
Front Links
Using Pro-line PowerStroke Shocks
Wishing for a jeep too
Fixing up the 4-links
Done.. ..
Wheelbase measure to be 325mm
Its JK Flex time.. ..
JK Transform.. ... ..
Thanks for viewing.. .. ..
Still need to fit the gear box, motor, lighting and others electronic items.. ..
» [ASK] Where to Buy RC Adventure Kits in Singapore?
» shop in singapore?
» Axial in Singapore
» Scaler rc. Uscita di Pasqua Jeep JK - Jeep Truggy Comanche
» Where to get HPI Desert Trophy in singapore?
