In total there are 13 users online :: 0 Registered, 0 Hidden and 13 Guests None
Replacing Glued tyres?
Hi Guys,
Want to ask: The tyres on my touring car keeps coming off as I take corners. Guess there is no choice but to glue them up. However, the touring tyres seems to be wearing off very quickly (due to lots of sliding and skidding ) so I am expecting to change out the tyres quite frequently at this rate.
So how does touring car owners manage the frequent changing of glued tyres? Do they use the same boiling / acetone methods mentioned above?
Appreciate if the seasoned tourers here can point me in the right direction.
Thank you
RCgolf
Thank you
RCgolf
RCGolf- Crawler
Re: Replacing Glued tyres?
Go for aluminium rims.
1st, they don't distort their shape in the long run. plastic rim will not be concentric after a few tyres change.
2nd, residual harden glue can be file away from the rim during tyre change without damage as compare to plastic rim.
3rd, they are bling bling........
speedstream- Crawler
Hi, I use UHU glue for easy removal.
Thanks guys for the inputs !!!
Wow, got to start looking for a source of cheap tyres, and rims too ... no more tamiya rims.boolean21 wrote:we just change the wheels and tyres as a set....
I am sure they will be ... Think my SCX10 also deserves the bling too ...speedstream wrote:Go for aluminium rims.
Hmmm, sounds like a great idea. Will have a go at this... wU-HUWrigleys wrote:Hi, I use UHU glue for easy removal.
RCGolf- Crawler
boolean21 wrote:check out ebay and r2hobbies....
per set of rims cost around usd4...
Thanks Boo!! will check them out.
RCGolf- Crawler
» Replacing Tires for Bruiser.
» Taking out glued tire
» Removing glued tyre from wheel
» Replacing Tamiya Tundra stock wheels
» WTB: 1.9 Tyres
» WTB: 1.9 Tyres
