In total there are 18 users online :: 0 Registered, 0 Hidden and 18 Guests :: 1 BotNone
» [Rifle Range Trail] Rifle Range Road - 22 Apr 2018 0900hrsby boolean21 Yesterday at 20:14
by boolean21 Sat 30 Dec 2017 - 16:16
by boolean21 Sat 2 Dec 2017 - 12:05
by boolean21 Sat 14 Oct 2017 - 8:54
boolean21 |
RTECH |
gionata78 |
laneboysrc |
oceanic |
Marpek |
babyboy |
Wrigleys |
ShaiAX55 |
Oceanic's TT01E Touring
Page 1 of 1 • Share •
Re: Oceanic's TT01E Touring
havent build yet, waiting for aluminum conversion kit from RCMART
oceanic- Moderator
woo hoo!!!!!!!!!
its touring time!! looking forward to the build thread!!
boolean21- Crawler
Cool!! I'm waiting for my ESC and motor from Hobby King before starting my build too.
When Kelvin's Gold edition TA05 comes together, let's all hit the tarmac track together.
RCGolf- Crawler
RCGolf wrote:Cool!! I'm waiting for my ESC and motor from Hobby King before starting my build too.
When Kelvin's Gold edition TA05 comes together, let's all hit the tarmac track together.![]()
Sure bro
oceanic- Moderator
Ahhhh! Nothing better than the smell of a new RC kit
Looks like I need to get onroad tires for my TT01 Fairlady drifter so I can join the road-fun.
laneboysrc- Crawler
Cool ! Some of the parts need hop-up if you are using brushless motor. The shaft and the motor mount.
When building , it is advisable to apply the tamiya AW(anti-wear) grease on the gears.
wow wow wow , looks like going to have a fierce races...........
kelvintan_hc- Crawler
RTECH wrote:Cool ! Some of the parts need hop-up if you are using brushless motor. The shaft and the motor mount.
Yes sir noted.
oceanic- Moderator
Fierce!!!! Nice work bro!
boolean21- Crawler
Great looking shell indeed!
Were the wheel arches pre-cut already? (On my DF03RA they are, which is fantastic as it is hard to get them nice and round)
laneboysrc- Crawler
thank you thank you...
newbie work, not perfect.
the wheel arches is not pre cut.
oceanic- Moderator
Bro your workmanship very good
kelvintan_hc wrote:Bro your workmanship very good
Thanks but its far from good. Far looks ok, go near see all mistake.
oceanic- Moderator
Very, very nice with the lights.
Body posts need shortening, then its ready for playing it seems!
laneboysrc- Crawler
Yea, just cut off those long post. You can extend it later on if you change to other shell.
Before you do that, i think you need to lower the shell a bit so that the aerodynamics of the shell can take into effect.
Hi oceanic wht servo u use for your tt01, coz I used bluebird servo cannot fit in my TA05
kelvintan_hc wrote:Hi oceanic wht servo u use for your tt01, coz I used bluebird servo cannot fit in my TA05
im using hitec. its a standard size servo
oceanic- Moderator
oceanic wrote:kelvintan_hc wrote:Hi oceanic wht servo u use for your tt01, coz I used bluebird servo cannot fit in my TA05
thks bro , will go look out for that
» oceanic's driver & build
» Zenith Trans-Oceanic H500
» Transistor totables
» body bushings/mounts
» oceanic's RC4WD Trail Finder 2 unboxing!
