by CraftRC Fri 10 May 2019 - 15:10
May 2019
2.4 GHz receiver antenna repair
2.4 GHz receiver antenna repair Empty 2.4 GHz receiver antenna repair
Post by laneboysrc on Mon 11 Feb 2013 - 18:56
Currently the LANE Boys residence is hosting a vehicle of a distinguished SGCrawler for fixing up some lights. When I took out the electronics the following image presented itself:
2.4 GHz receiver antenna repair 8463741765_62281264c3
Notice something missing?
Yes, the antenna has been cleanly ripped out of this poor receiver. Time to get out the soldering iron...
The antenna connects to the round soldering pad and the vertical strip on the left side of the receiver, shown in the following picture:
2.4 GHz receiver antenna repair 8464839684_ea4340f00a
First clean off the soldering pads, removing any left-overs from the original antenna. De-soldering braid is very useful for this job.
The antenna is simply a 19 cm long piece of 1.2 mm thin COAX wire. I found some spare wire in an old Wi-Fi equipment that was no longer in use.
2.4 GHz receiver antenna repair 8464839626_61f9a52718
On one side carefully strip off 2 mm of insulation using a sharp hobby knife. This exposes the shielding braid.
2.4 GHz receiver antenna repair 8463742293_74614f0645
Unravel the braided wires and form two neat bundles on opposite sides.
2.4 GHz receiver antenna repair 8464839512_51242800fd
The following picture shows how the wire will be mounted on the receiver.
2.4 GHz receiver antenna repair 8463742153_8f83037064
Now strip of approximately 0.5 mm of the insulation of the centre wire.
Then pre-tin the centre wire as well as the shielding lobes.
2.4 GHz receiver antenna repair 8463742057_15bf70c8da
Solder on the centre wire, then each side of the shielding wires.
2.4 GHz receiver antenna repair 8464839256_ecf3e8d9d2
This completes work on the receiver, but we still need to form the actual antenna.
Strip off exactly 26 mm of the outer insulation. You need to be very precise as this affects the quality of the antenna.
2.4 GHz receiver antenna repair 8463741883_5f4c47f354
Unravel the braid and cut it off exactly at the remaining insulation. This completes the antenna.
2.4 GHz receiver antenna repair 8464839086_94cbcc3e7b
Do perform a range check to ensure it is working fine!
2.4 GHz receiver antenna repair Empty Re: 2.4 GHz receiver antenna repair
Post by wyetuck88 on Mon 11 Feb 2013 - 20:53
Brilliant work as usual!!!
Post by boolean21 on Tue 12 Feb 2013 - 6:29
Nice work!
