shocks with leafs or 4-link?
Post by qks57 on Sat 3 Sep 2011 - 22:41
i'm intending to get a scaler guys, and it comes with scale shocks and 4-link suspension. i intend to put in a set of leafs for the truck, is it possible to use leafs, shocks and 4-link all together? or can i only use either leafs or 4-link? which performance is better?
thanks for all comments in advance! Smile
Re: shocks with leafs or 4-link?
Post by Marpek on Sun 4 Sep 2011 - 15:03
bro, you can have either one setup with the shocks...that said if you have leafs, the 4 links will be just cosmetic. Of coz the links performance will be better than leafs...
Post by qks57 on Sun 4 Sep 2011 - 17:32
hmmm ok.. 1 thing about the leafs and links, which will give more ground clearance? or is it dependent on setup?
Post by Marpek on Fri 9 Sep 2011 - 10:24
Both sama sama( same ), depends on the gearbox and tranny. Eg, the highlift with the newer 3 speed gearbox is a hindrance( but it`s not crawler specific chassis anyways ) compared to the older model.
