Babyboy's M - Alfa Romeo
Here's my Mini. After 3 days of finding time.... here's what I got with the help from my daughter in sorting the screws. Straight forward build from the box with the instruction. Better than Axial in term of bag A B C where you find all things needed to build that particular part. Still having issue from Axial QC on parts that dun fit on my 3rd Kit.
Upgrades with ball bearing and shocks.
[img][/img]
[img][img][/img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
Manage to strip 4 screws up to this point... Need help from here onwards. The rear is set to toe in and the front toe out... the front toe out is so much? I followed the instruction on the spacing required and the toe out is soo much from my point of view. Do I really need so much toe out?
Noob question. The sponge provided need to trim the length and squeeze in the tyre? Do I need to trim the width? Need to check before I actually cut it to ensure that I'm doing it correctly...
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
Re: Babyboy's M - Alfa Romeo
yeah!!! finally you found time to start on the M-chassis build!
looking forward to updates!
no idea about your queries.... wait for the SGC M-club experts'advises!
will keep a look out here so that i will know what to do if i get a M in the near future!
Great to see you found some time building it!
The toe out in the front seems a bit excessive, but maybe the camera distortion makes it worse than it is, plus you have no battery in the car which will also make a difference when there is weight on the front axle.
From the photos it looks like the gap between the steering link ball ends may be too small, making the links too short hence too much toe-out, There should be 2mm gap between the adjuster pieces; yours looks like closer to 1.5mm (though hard to see on the photo). Refer to the manual step 15.
The sponges are already the correct size, no need to trim. Push them gently into tires and they will fit nicely after a bit of careful massaging. Make sure the ends meet up nicely. Then put the tires on the rims.
What shocks are you using? The M-06 needs very stiff springs in the back as there is a lot of weight in the back. It looks yours has the same springs front and rear, which could mean that either the rear is too soft and will bottom out on the slightest bump, or the front will be too hard. The kit comes with really hard golden color springs, but unfortunately they don't fit on aftermarket shocks.
The shocks look similar to the Yeah Racing ones I have. Mine came with red (soft), yellow (medium) and blue (hard) springs. I am using red on the front, and blue on the back. I also changed to a 600 weight shock oil with a one-hole piston for the rear as it was too bouncy (stock was 2-hole piston with 400 oil, yellow in color as supplied in the Tamiya kit). And I moved the top mounting to the center hole instead of the outer most. I haven't had a chance to drive after the changes so I am not sure how well it is tuned now, but with yellow springs, 2 hole piston and standard 400 oil it bottomed out a lot and bounced around.
Regarding stripped screws: you may have the wrong type of cross-head driver. I use a "PH-2" that fits snug and never stripped a screw.
One more thing: many of us discovered that the supplied servo saver is garbage. Unusable. It has so much slop that every time the car goes over a bump the steering goes out of trim. The cure is to use the Tamiya 51000 high torque servo saver. Do not run without servo saver, because if you have a crash then the plastic steering parts will bend (don't ask how I known )
boolean21 wrote:yeah!!! finally you found time to start on the M-chassis build!
The near future is here . Stargek is having a 20% sale! Was there yesterday to get paint for my Mini Alfa Romeo.
laneboysrc wrote:Great to see you found some time building it!
Yes the camera makes it looks very excessive. The gap is as shown in the manual. So this is normal after battery is mounted. Thanks
laneboysrc wrote:
The sponges are already the correct size, no need to trim. Push them gently into tires and they will fit nicely after a bit of careful massaging. Make sure the ends meet up nicely. Then put the tires on the rims..
Errr tried but seems the sponges are too long to go only 1 round... will try again tonite. Will massage the sponge more . Thanks
laneboysrc wrote:What shocks are you using? The M-06 needs very stiff springs in the back as there is a lot of weight in the back. It looks yours has the same springs front and rear, which could mean that either the rear is too soft and will bottom out on the slightest bump, or the front will be too hard. The kit comes with really hard golden color springs, but unfortunately they don't fit on aftermarket shocks.
Yes, its the Yeah Racing shocks. Good that you pointed out. Will change to the red spring for the back. Thanks.
laneboysrc wrote:Regarding stripped screws: you may have the wrong type of cross-head driver. I use a "PH-2" that fits snug and never stripped a screw.
Thanks for the heads up.
laneboysrc wrote:One more thing: many of us discovered that the supplied servo saver is garbage. Unusable. It has so much slop that every time the car goes over a bump the steering goes out of trim. The cure is to use the Tamiya 51000 high torque servo saver. Do not run without servo saver, because if you have a crash then the plastic steering parts will bend (don't ask how I known )
Thanks for the tip.
Great info for a newbie like me. Thanks Werner!
babyboy wrote:Yes, its the Yeah Racing shocks. Good that you pointed out. Will change to the red spring for the back.
Blue (hard) in the back, Red (soft) in the front!
Woohoo, another M to join us during the next tour
RCGolf- Crawler
Soooo.... When is the next massive Race!!!
Still have to setup the esc. My bec have not solder up yet. For now am using the spare crawler esc. So it is crawling at the moment.
» Tamiya FF02 Alfa Romeo 156 Racing
» Tamiya M06 Alfa Romeo Giulia Build - Boolean21's M-chassis
» [M-CHASSIS VIDEO] Tamiya M03 vs M05 vs M06 Alfa Romeo Giulia Mini Cooper Datsun 510 Nissan Cube 1:10 scale M-chassis shoot out at Woodlands Hardcourt
