New kid in the block! TT-02
The Legend has finally evolve...
Re: New kid in the block! TT-02
At Stargek they have already a display model of the bare chassis. Looks like they did some improvements of the TT01 as well as get the cost down even further. Now they just need to release different bodies on it.
Good to see they released the Integrale already. Will ensure that the body stays available so I don't have to worry when bashing it up on my DF03ra
Yeah...the lancia body looks fantastic man!
Looks pretty good to me with little hop ups....ok wor!
I dun see any improvement, still the same old plastic car.
And they still use back the suck plastic propellar shaft.
undefined wrote:
Probably newer designed tub, suspensions and materials to cut some weight.
RTECH wrote:I dun see any improvement, still the same old plastic car.
Well, it is a rock-bottom entry level car, so the plastic is expected. Apparently the propeller shaft is now carbon-reinforced plastic and is no longer a "must upgrade immediately" item, even for running brushless.
What I find interesting is that they have been able to lower the price: several sites list TT02 kits for less than the old TT01.
I see . Actually i was hoping they reinforce all plastics parts with carbon. But they only did it on the shaft. But the shaft reinforce with carbon is a bad idea. Although it will make it more stronger but more brittle. The old shaft is more flexible with brushless motor. It just bounce around .
RTECH wrote:I see . Actually i was hoping they reinforce all plastics parts with carbon. But they only did it on the shaft. But the shaft reinforce with carbon is a bad idea. Although it will make it more stronger but more brittle. The old shaft is more flexible with brushless motor. It just bounce around .
Last time when I was active with nitro touring... every week must standby at least 100bucks in wallet for spares... Touring spare expensive gila...
Dunno this one is consider what class but its 1/10... Spare sure expensive...
Banzai hobby has is under usd80.... currently on pre-order though....
Bbb!!!
Bbb!!!
» ken block wr8
» Just for ken block only.
» KEN BLOCK'S GYMKHANA FIVE
» WR8 Ken Block bashing at DIOT
» HPI WR8 Ken Block painted body at Tai Seng
