HobbyKing 6V 3A BEC
HobbyKing 6V 3A BEC
Post by laneboysrc on Thu 18 Apr 2013 - 21:00
Hi folks,
I noticed that HobbyKing has a little 6V 3A BEC for sale now, and since the cost is moderate at USD 4.03 I've put some in my shopping basket during the last order.
Tamiya kits often still come with an ESC that doesn't include a BEC (e.g. TEU-101BK or TEU-104BK; TEU-105BK does have a BEC!), it may be an interesting product for some of us (Mini owners especially!)
This is a first look, I haven't done any electrical test yet.
Dave Jones from EEVBlog wrote:Don't turn it on, take it apart!
The BEC is small 23 x 21 x 8 mm, it is actually thinner for most part, only the output capacitor is bulky.
Underneath the heat shrink is a shielding alu foil, which is glued down with Kapton tape for insulation. Opening up the shield, e.g. for changing the wiring, is destructive to the tape and foil.
The output wiring is a bit on the thin side. The soldering on the board is a bit shoddy, but I've seen worse. This BEC is a switch mode BEC, so it will be efficient and should be fine for the rated output.
So far so good. I will report when I have more findings -- positive or negative...
Re: HobbyKing 6V 3A BEC
Post by boolean21 on Thu 18 Apr 2013 - 21:08
Thanks for the reviews....
I'm hoping for the best as i have a few of them and some 3.3V ones in my trucks... Very Happy
Fingers crossed... Very Happy
Post by coldman28 on Thu 18 Apr 2013 - 21:44
awesome review by our electronic expert......
