Selling Stock Summit Traxxas EVX-2 ESC and TITAN 775 both for only $100SGD with free 2x 3000mAH battery packs
Post by purexc on Sun 19 May 2013 - 13:08
Waterproof Electronics and Titan 775 Motor
Summit gets its spin from the largest motor of any electric monster truck, the Titan® 775. This massive mill is equipped with a fan-cooled armature for nonstop off-road adventure, and an extra wrap of steel around the can for maximum magnetic field strength—that means more torque to tame the trail and conquer any climb. Designed by Traxxas, the EVX-2 features three drive profiles, thermal shutdown protection, low-voltage detection for compatibility with LiPo battery packs, and Traxxas high-current battery connectors. Throttle control comes from an EVX-2™ electronic speed control, a heavy-duty powerhouse that can handle up to 16.8 volts to give Summit extreme trail-conquering torque. And if that trail is wet, muddy or even covered in snow, it's no problem. Waterproof electronics let Summit operate worry-free in conditions that sideline other monster trucks.
http://www.rcmart.com/traxxas-3019r-evx2-electronic-speed-control-p-35884.html?cPath=1560_51
Description:
For 16.8-Volt Dual-Battery Dual-Motor Setups! EVX-2™ Waterproof FWD/REV ESC with Low Voltage Detection (LVD)
The EVX-2 delivers an incredible 16-plus volts, from two battery packs, making 16.8-volt, twin-motor setups more powerful than ever! Designed by Traxxas, the EVX-2 features a completely waterproof design, three drive profiles, Thermal Shutdown Protection, and gold-plated Traxxas High-Current Connectors. The EVX-2 also includes patent-pending Training Mode.™ This profile reduces the overall power output of the EVX-2 by 50% making it easier for young/new drivers to develop their control skills before unleashing full-power operation. EVX-2 is equipped with two-stage low voltage detection (LVD) to allow LiPo battery use. The EVX-2 is manufactured by Traxxas to ensure the highest level of quality and support. The EVX-2 is backed by the Traxxas Lifetime Electronics Warranty.
Feature:
16.8 Volts of power
Traxxas High Current Connectors
Three Drive Profiles
Patant Pending Training Mode
Waterproof Design
Double Coated Electronics Prevent Water Damage
EZ-Set Push Button Setup
Microprocessor Controlled
Specification:
Input Voltage: 6-14 Cells (7.2 - 16.8V)
Case Size (WxDxH): 2.27x2x1.05"
Weight (w/o Heatsink): 3.6oz
Motor Limit: 540 - 10 turn/550 - 12 turn
On Resistance: 0.004 ohm
Rated Current: 180 Amps
Braking Current: 360 Amps
Reverse Delay: None
BEC Voltage: 6V DC
BEC Current: 2.5 Amps
Power Wire: 14awg 3"
Input Harness: 26awg 9.5"
Motor Wires: 14awg 9"
Transistor Type: Mosfet
PWM Frequency: 1700 Hertz
Protection: Thermal Shutdown
CONTACT ME AT 9326 4120
purexc
