In total there are 9 users online :: 0 Registered, 0 Hidden and 9 Guests
May 2018
Waiting for my Hoot to arrive!
Page 2 of 2 Previous  1, 2
Re: Waiting for my Hoot to arrive!
Post by RTECH on Wed 28 Sep 2011 - 22:13
Wrigleys wrote:Keep the ideas coming in man.. Haha my front left shock absorber leaking liao.. Any good suggestion for replacement? Once I get a list of items den I go hoot liao.. cyclops
Leaking? Maybe you try re-assemble the shock and check the seal.
Post by Wrigleys on Wed 28 Sep 2011 - 23:24
Ok thanks! Will update. Any idea where to buy top up shock oil locally in case I need it?
Post by qks57 on Thu 29 Sep 2011 - 1:05
a good place will be Tai Sing, they have a very wide range of shock oils to choose from. Smile
Post by RTECH on Thu 29 Sep 2011 - 22:33
You can either get from jet hobby at ubi ave 3, Vertex or rotor hobby at kitchener road blk 808. If you dun mind china oil.
Post by boolean21 on Thu 29 Sep 2011 - 22:36
Bro, I still have 25wt shock oil... U can have some if 25wt is suitable for you. Smile
Post by Wrigleys on Fri 30 Sep 2011 - 12:56
ok guys.. been wondering and did a search for these items but still no answer..
This bag came separately from the RTR box. Pieces of screws about 1.5cm long.
This came with the RTR but no idea what are these items except for the 2 fasteners for the body shell.
I have circled the gray wire. Is that the antenna?
The drive shaft popped out a few times while test driving the other day while climbing on some tree roots. I realised there are no screws attached for the front and back shafts. Could it have unwinded itself and dropped out or not there in the first place? I tried looking for a fix and found out that I have to screw and apply lock tite.
I am looking for aluminium links upgrades for the scx 10. Is this the one? AX30550 - SCX10 TR Links Set - 12.3" / 313mm
From what I understand, this aluminium link replaces all the plastic links I have circled.
Thank you many many! Smile
Post by Wrigleys on Fri 30 Sep 2011 - 13:06
Ok now I realised I have to find those mini screw drivers to take out the mini sized screws. I guess the tools do not come with the RTR correcT? Hardware store got sell right normally? The mini drivers with the red casing.. Thank you guys for your help!
Post by boolean21 on Fri 30 Sep 2011 - 13:13
Hi bro...
I don't remember seeing the spare silver bolts but my rtr do come a few bags of spare stuffs... Mine us the old version though...
The pc with the 2 clips, the tube looks like the tube to hold the antenna, the other is the bind plug...
The one coiled in the other picture looks like the antenna... there is a place around there that you can attach the antenna tube, and slot the antenna through the tube
The link set should be the right one, based on the wheel base you stated...
You can also diy the links if you want... Much cheaper...
Post by boolean21 on Fri 30 Sep 2011 - 14:23
Bro... I think honcho all hex hardware... Not screw drivers....
Buy the hex key set... 1.5mm 2mm 2.5mm 3mm
Post by RTECH on Fri 30 Sep 2011 - 21:46
No The axial RTR comes with a bit of giltches. Dunno wat the hell happens in their assembly line. My wraith diff assemble in the wrong direction, some screws over tighten until loose.
Post by Wrigleys on Fri 30 Sep 2011 - 22:21
Oh yes.. Gotta get the hex drivers.. No wonder the thread on the screw different.
Btw the axial rtr is made in Taiwan as stated on the invoice.. Hmm..
Post by RTECH on Fri 30 Sep 2011 - 22:25
Made in Taiwan hmm.... maybe they employ china or bangala workers to assemble?
Post by slow on Sat 1 Oct 2011 - 16:54
Bangala worker??????
Post by boolean21 on Sat 1 Oct 2011 - 16:56
slow wrote:Bangala worker??????
Haha....
