Boolean21's Preferred Chassis Fabrication Scorpion 4x4 - 1:10 tuber
Post by boolean21 on Thu 4 Jul 2013 - 0:21
Had been wanting to build a Scorpion 4x4 for a very long time...
Some info on the Preferred Chassis Fabrication Scorpion 4x4 -> http://www.scorpion4x4.com/
" The Most Capable 4x4 Ever"
The Scorpion is the ultimate in civilian recreational search & rescue, military and law enforcement vehicle
Some photos of the 1:1 Scorpion 4x4....
So... bought this tuber body from bro Teck quite some time back... What a Face What a Face
it is some what similar to the Scorpion 4x4 chassis.... close.... but different..... different but similar... Very Happy:D:D
So... i striped the panels....
sanded down..... and more sanding...
then primed with grey primer.... and sprayed with "Steel Grey" and coated with matte clear.....
that's all for the past few days.....
at least it got started! Very Happy
thanks for looking! Smile
Re: Boolean21's Preferred Chassis Fabrication Scorpion 4x4 - 1:10 tuber
Post by Zax13 on Thu 4 Jul 2013 - 5:18
Great job bro... Cant wait for the finish product.... Very Happy
So how many piece can you make? Embarassed
Post by boolean21 on Thu 4 Jul 2013 - 6:59
Zax13 wrote:Great job bro... Cant wait for the finish product.... Very Happy
Haha bro.... i didn't make the tube.... Very Happy
It is a full metal Integy Tuber.. Smile
Will me just making some simple panels for it.... Smile
Post by laneboysrc on Thu 4 Jul 2013 - 8:34
Fantastic, really love the shape of this vehicle. Looks like a tough frog
Post by RTECH on Thu 4 Jul 2013 - 19:35
The SAF buggy looks like the scorpion.
Post by Marpek on Fri 5 Jul 2013 - 19:23
Nice!!!
Post by Harakiri on Sat 6 Jul 2013 - 17:57
What a Face
Post by boolean21 on Sat 20 Jul 2013 - 1:41
some spare midnight oil to burn.... so continued the build...
was choosing whether to use the spare AX10 part to transfer over to the Integy tuber chassis.... or to use the rc4wd T-Rex 60 axles....
i decided to go for the easier method.. transfer the ax10 parts over...
so first thing to do was to take the transmission assembly off from the ax10....
the 55t motor will be replaced with a 550 sized silver can....
took apart the transmission and filled it up with marine grease....
then assembled it back together with the spur gear cover....
broke the 1.5 hex driver while removing a grub screw on the drive shaft... No No
made some lower links using threaded rod and M4 rod ends as the links on the AX10 are too long....
lower links are now 9.5cm "eye to eye".... 1cm shorter than the AX10 lower links...
replaced the shocks to 85mm shocks as well....
some shots with the potential future driver for this rig.... Smile
Post by laneboysrc on Sat 20 Jul 2013 - 8:20
Sweet, starting to look like a car already!
Post by Wrigleys on Sat 20 Jul 2013 - 10:39
Power! Another beauty/beast to your collection! Very Happy Very Happy
Post by boolean21 on Tue 17 Dec 2013 - 23:20
The scorpion has always been in my mind.... hasn't forgotten it.... just that time is really scarce.... Sad
finally... managed to trace out some panels using some cardboard... then trace the cardboard onto styrene and made the bonnet, side panels and roof...
here are some photos...
the bonnet.....
the side panels....
and the roof....
needs some sanding down.....
that's all for now...
Post by oceanic on Wed 18 Dec 2013 - 6:48
Looks good!
More more!
Post by babyboy on Sat 21 Dec 2013 - 1:13
Nice! Wish I can get one...
Post by boolean21 on Sat 7 Jun 2014 - 22:32
no no... i didn't forget about this build nor did i wanna give up on the scorpion 4x4....  Evil or Very Mad  Evil or Very Mad  Evil or Very Mad  Evil or Very Mad
just too tied up with stuffs....  What a Face  What a Face  What a Face
here's some updates....
my plan for the scorpion 4x4 is have 4 wheel steering.... always wanted to have a truck with 4WS.... and scorpion seems to be the right candidate.... Smile
so.... i would need rear steering links for the scorpion....
the front steering links of the scorpion are the green AX10 links....
so i look thru the trucks and notice that my land rover has the green AX10 links....
so it'll be the donor for the rear steering links....
looked through my spares box and found the topcad steering links for scx10....
these will go onto the defender... Smile
So... out come the green links....
and in goes the topcad steering links....
done on the donor!
now.... installing the green steering links onto the rear of the scorpion 4x4
now for the servos.... managed to dig out a few hobbyking servos from spare pool.....
and will be using these.... low cost waterproof servos.... rated 12.8Kg torque.....
don't know how good they are.... but will just try them out... Smile
installed the rear servo....
and this servo on the front will also be replaced by the hobbyking servo
done!
had set up the truck for 4WS and will do up the video and post soon!
Post by wyetuck88 on Sat 7 Jun 2014 - 23:25
Looking Sharp!! cyclops
Post by babyboy on Sun 8 Jun 2014 - 9:37
Wow... nice. Havent tried 4WS before. Think must put in the to do project.
Post by boolean21 on Sun 8 Jun 2014 - 10:03
here's a short clip to demo the 4 wheel steering functions provided by the low cost GT3B transmitter. Smile
Post by babyboy on Sun 8 Jun 2014 - 16:49
Woohoo! Didn't noe got multi mode steering. Power man! The first in SGCrawler.... Nice!
Post by boolean21 on Sun 8 Jun 2014 - 16:53
babyboy wrote:Woohoo! Didn't noe got multi mode steering. Power man! The first in SGCrawler.... Nice!
No la bro.... not the first one la...
 Evil or Very Mad
Post by boolean21 on Thu 3 Jul 2014 - 0:15
was very inspired by bro Robert's camouflage fleet.....
but without his skills.... painting a camouflage truck is too much of a challenge for me....  Evil or Very Mad Evil or Very Mad Evil or Very Mad Evil or Very Mad
so.... i tried the easy way out....
googled for some camouflage prints.... and settled down for a digital camouflage print....
printed the camouflage design.....
then wrapped the panels with the camouflage print stickers...
and there it goes!
Post by laneboysrc on Thu 3 Jul 2014 - 8:44
Great following the new trend: plastic wrap instead of paint!
Ready for Sunday's trail!
Post by RTECH on Thu 3 Jul 2014 - 18:05
lol! That's cheating ! Haha... but well done ! Looks nice.
Post by boolean21 on Thu 3 Jul 2014 - 19:32
laneboysrc wrote:Great following the new trend: plastic wrap instead of paint!
still not quite ready... still need to dig out the winch I bought for this truck.... and mount a seat.... and look for a machine gun. ....
RTECH wrote:lol! That's cheating ! Haha... but well done ! Looks nice.
Hahaha... no choice.... no skills... have to think of other ways.... Very Happy Very Happy
Just realised this project kick started last year!
At least some progress in one year.... Very Happy
Post by Zax13 on Thu 3 Jul 2014 - 20:49
Took you awhile to complete this project....  Very Happy
Post by boolean21 on Thu 10 Jul 2014 - 21:09
received a kind donation of fire arms from bro Liew....
a 1:6 scale GPMG !
test fitted the GPMG on the roof....
yeah... it's big.... but still acceptable i hope! Very Happy
oh now i need a micro servo to control it.....
oh yes.... i've got a 360 degrees micro servo available! Very Happy
Post by boolean21 on Thu 10 Jul 2014 - 22:52
more hands on the scorpion 4x4 build....
dig this out from the hobbyking goodies....
ordered this quite some time back for this project.... recommended by bro Robert...
Dr Mad Thrust machine gun sound effects....
and also another piece of this....
Dr Mad Thrust's receiver controlled BEC....
this will be used to control the turning on and off of the machine gun sound effects....
mocked up the GPMG and did a trial....
the 360 degrees micro servo definitely has enough power to turn the GPMG... Very Happy Very Happy Very Happy
and one good thing about 360 degrees is that, i can just adjust the subtrim off center and the GPMG can keep rotating automatically.... Smile
took some photos of the mocked up rig....
that's all for today....
Post by wyetuck88 on Fri 11 Jul 2014 - 1:27
Looks good!
