scx10 important hop ups
Ezekiel Freshmen
sgsone
Hi guys... just wondering what hop ups help the most for the scx10 rtr so as to plan my budget, like aluminium suspension links? Titanium shocks?
Thanks
Thanks
sgsone- Crawler
Re: scx10 important hop ups
Hey, stop creating sooooooooooo many threads and just reply in your first thread ~~~ -.-
Ezekiel Freshmen- Crawler
Ezekiel Freshmen wrote:Hey, stop creating sooooooooooo many threads and just reply in your first thread ~~~ -.-
Hey ezekiel
the admin and mods is maintaining this forum, let them decide if its ok or not.
he is new, dunno much. many threads with different subjects is none of your concern.
Ask more ask more.... that's the way we learn...
I used to ask a whole lot of questions and I'm still asking now.
Like babyboy mentioned in another thread, upgrade the links... either diy metal links from threaded rods or get the metal hop ups..
sgsone wrote:Hi guys... just wondering what hop ups help the most for the scx10 rtr so as to plan my budget, like aluminium suspension links? Titanium shocks?
Thanks
Depends on the model of scx10 you are getting... go to axial racing.com, look for the model you are interested, download the manual.... the links are all different lenght. Get the correct lenght. Do check if they come in aluminium or plastic. Else get the truck first and see if you can mod the link.
Most will advise to get the four link. So look up axial racing to get the info from manual.
Supplied shock is more than enuf to trail. We change shock is because of looks, droop effect, bouncy effect, truck too heavy, oil leakage etc etc.
When trying to DIY, do factor in costs such as transport, time and your skill level, and Comparing it to store bought items. As you're already into drones, you can use the cross motor mount as a suspension lift kit or droop setup.
Also, the countersunk screw you use to mount the motor onto the mount, you can use them to seal the holes in the rims. There're also parts in your heli toolbox that you can use, like the push rods and grub screws.
Besides performance parts, you should also get materials to maintain and protect your truck.
___________________________________________
Marine Grease, for axle water proofing and all gears.
http://radiocontrol-sports.com/
Retail Outlet
150 South Bridge Road
#01-07, FookHai Building
Singapore 058727
WD40 or Bearing oil
Lemon Pledge, this helps to let dirt to just fall off my truck, also covers scratches and makes the body shiny like new.
https://www.isetan.com.sg/products/pledge-furniture-polish-lemon
just go to any value dollar shop to get it at $5, this is what bikers use to polish. harley davidson bikes.etc
China Square, opposite FookHai Building
NECA 7" inch figurines for the driver
I recommend these upgrade parts.
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=14848
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=29775
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=22380
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=23554
For electronic waterproofing, you can go figure out the many ways or get this epoxy.
http://www.hobbyking.com/hobbyking/store/__8684__Quick_Cure_5_Min_Epoxy_Glue_4_5_oz.html
I've tested it on mine and is still working.
Common mama shop Superglue for the tires in case not fully sealed. Don't need expensive tire glue, I try le.
BLUETACK !! to stick your scale accessories !!
Other useful stuff but may not be necessary,
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=9710
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=12316
Retail Outlet
Singapore 058727
WD40 or Bearing oil
Ezekiel Freshmen wrote:When trying to DIY, do factor in costs such as transport, time and your skill level, and Comparing it to store bought items. As you're already into drones, you can use the cross motor mount as a suspension lift kit or droop setup.
Retail Outlet
Singapore 058727
WD40 or Bearing oil
thanks, that is quite a lots of info!!!
