In total there are 12 users online :: 0 Registered, 0 Hidden and 12 Guests
CC01 Enquiries
CC01 Enquiries
Post by liammielicious on Sat 6 Jul 2013 - 16:10
Dear crawler bros, me and my bro just gotten the cc01 kit....so hopefully will be able to get some tips on how to 'crawl' or a better word to say 'trail' our trucks better ya??
gonna take some time to build though....lol
see ya guys soon y'alll
liammielicious
Re: CC01 Enquiries
Post by Zax13 on Sat 6 Jul 2013 - 17:10
Congrates on your purchase... built thread please...
Re: CC01 Enquiries
Post by Liew on Sat 6 Jul 2013 - 17:26
Lock the front diff n New tire ;D
Re: CC01 Enquiries
Post by liammielicious on Mon 8 Jul 2013 - 13:22
liew bro, i tot should lock the back diff instead?
yeah...looking at 1.9 tyres...but where to buy cheap and good tyres and rims bro?
tried junfac and asiatees.  the prices ok?
prob, pop by swan soon and look for winnie
liammielicious
Re: CC01 Enquiries
Post by Liew on Mon 8 Jul 2013 - 18:50
Front n Rear  need lock diff
U need high turn motor too
Re: CC01 Enquiries
Post by laneboysrc on Tue 9 Jul 2013 - 9:15
Indeed just locking either front or rear is not enough for any serious trailing. With both diffs locked is is passable.
But all the gears are plastic so locking the diffs provides a lot of stress on to them. Expect them to wear rather quickly if you use the vehicle a lot.
The kit comes with one set of lockers for one diff (two triangle-shaped pieces on the G sprue), the second diff can be locked by wedging the spider gears. See http://www.rccrawler.com/forum/tamiya-xc-cc01/182426-blackfoots-cc01-project-some-simple-diy-mods.html
As Master Liew said you will need a high turn motor (45T, 55T). The stock 27T silver can makes it go quick, but at the expense that it has very little torque at the low speeds required for trailing.
I don't have a recommendation on tires, other than that the stock are way too hard. When getting other tires you need to pay attention to the outer diameter -- the CC01 tires are 1.9" but have a small outside diameter.
People have fit larger tires, but that requires cutting the body shell and other mods.
Junfac and AsiaTees are good sources for reasonably priced parts of good quality.
Ensure you upgrade the wheel-hex to metal ones. I recommend the original Tamiya one's "Pin Type Wheel Adapter #53056)". Also the steering should be upgraded out of the box. I had success with GPM parts, see my blog at http://laneboysrc.blogspot.sg/2012/12/tamiya-cc-01-steering-repair-using-gpm.html
Build thread with photos please!
Last edited by laneboysrc on Tue 9 Jul 2013 - 9:16; edited 1 time in total (Reason for editing : spelling fix...)
Re: CC01 Enquiries
Post by liammielicious on Tue 9 Jul 2013 - 13:18
saweeeeeeet la, bro laneboy!!!
tks so much for the tip manzzz
kk will take as much pics as i can bro  waitin for partssss
liammielicious
Re: CC01 Enquiries
