Tamiya MFC-02 and 2S Lipo compatibility
Hi guys,
Long time admirer of the forum so first of all thanks for sharing your expertise and knowledge - much appreciated. I have a question relating to the Tamiya MFC-02 unit. I'm about to build my highlift hilux and the MFC unit has its own ESC. I want to upgrade to a 2S lipo pack but i'm not sure what current draw I should aim for. I cant find any information on the max amperage for the internal BEC. I want to get something like a 5000+ Mah 60C pack but i'm worried i'll fry the MFC-02 (its pretty costly after all). I'm planning on running a high torque servo for steering duties and initially run the stock motor (27T) with an eye on upgrading to a higher turn motor (so less draw). Any advice on the best battery and servo combo would be most welcome!
mmu16
mmu16
mmu16- Crawler
Re: Tamiya MFC-02 and 2S Lipo compatibility
hi,mmu16 wrote:Hi guys,
mmu16
welcome on board...
i can't find any voltage specs on the mfc-02... but IF it can support a 2S lipo, max amperage doesn't harm the mfc-02.... higher amperage ratings on the lipo only gives you more run time...
hope it helps... just check your manual to see if you can find the specs stating the MAX INPUT VOLTAGE...
and lastly... post your build thread!
HI mmu16,
Welcome to SGCRAWLERS..
» Tamiya TBLE-02S modification for 2S LiPo cut-off
» Tamiya TEU-104BK modification for 2S LiPo cut-off
» Cheap and good lipo
» Monitoring LiPo Batteries and LiPo Safety
» WTB Lipo charger
» WTB Lipo charger
