July 2018
Tallest 2.2 tyres for rock crawling?
Post by boolean21 on Thu 22 Sep 2011 - 8:16
Hi bros,
Any idea whats the tallest 2.2 tyres that is good for rock crawling?
Re: Tallest 2.2 tyres for rock crawling?
Post by n4smw26 on Thu 22 Sep 2011 - 11:25
Not sure which is the tallest tires.. But them rovers seemed pretty tall..
Post by boolean21 on Thu 22 Sep 2011 - 11:49
n4smw26 wrote:Not sure which is the tallest tires.. But them rovers seemed pretty tall..
where to get them? will google more info on hb rovers...
Post by qks57 on Thu 22 Sep 2011 - 15:23
so far i think Proline's Interco Super Swamper 2.2 are the tallest at 5.4".. i got a set of them.. Very Happy
Post by boolean21 on Thu 22 Sep 2011 - 15:57
qks57 wrote:so far i think Proline's Interco Super Swamper 2.2 are the tallest at 5.4".. i got a set of them.. Very Happy
thanks for the info. Smile
Post by RTECH on Thu 22 Sep 2011 - 18:00
For rock crawling, 2.2 size rigs , recomanded tires size is 5 to 5.5 inches depending on the setting of your rig. There will be a sweet spot in between the range of 5 to 5.5 inch that suit your rig. Too high will increase your rig CG and tumble over.
5 to 5.25 inches is easy to set your rig to success. If you are using 5.5 inch tires need to reinenforce the side wall of the tires to prevent fold over . Side wall of tires can reinenforce by cutting pieces of lexan and insert into the tires or increase the stiffness of the foam.
Post by boolean21 on Thu 22 Sep 2011 - 18:14
RTECH wrote:For rock crawling, 2.2 size rigs , recomanded tires size is 5 to 5.5 inches depending on the setting of your rig. There will be a sweet spot in between the range of 5 to 5.5 inch that suit your rig. Too high will increase your rig CG and tumble over.
Wah... i've got a lot of learning to do.... Smile
Post by RTECH on Thu 22 Sep 2011 - 19:11
Increasing ground clearance of your rig depends on wat type of rocks you are crawling. Large and smooth rocks don't need much clearance, best run on droop setting. Smaller , sharp edges rocks require more ground clearance.
Normally rock crawlers will get stuck on the lower links and belly. Increasing the tire size only helps a little. Best is to use bent links and increase the belly height ( something like the mantis chassis).
Increase the weight to the front . Rear should not be heavy as this could result in the rig being pull back when crawling uphill. When crawling downhill, if the rig rear is light, it will tends to lift up. This is where the dig comes into operation. When the dig is engage the front of the rig will force to pull the locked rear in which cause the rig to squat. You can see the rig is squating when the rear shock is compress. This prevent the rear of the rig from lifting up.
Post by boolean21 on Thu 22 Sep 2011 - 19:33
Wanna gear up betty a little for next month's event!
Maybe betty should wear a tube top.... More sexy.....
maybe let her wear the g-air high heels first... And find a sexy tube top for her... See whether she can shine a little in next month's beauty pageant... Wahahaha....
Post by RTECH on Thu 22 Sep 2011 - 20:00
boolean21 wrote:Wanna gear up betty a little for next month's event!
Maybe i tell your wife about betty... Razz
Post by coldman28 on Thu 22 Sep 2011 - 20:23
you wanna check this out.
RC4WD rock crusher
Post by boolean21 on Thu 22 Sep 2011 - 21:26
coldman28 wrote:you wanna check this out.
RC4WD rock crusher
Thanks bro!
Post by n4smw26 on Fri 23 Sep 2011 - 1:59
eh boo, proline tuber can sell u. forgot to tell u.
Post by boolean21 on Fri 23 Sep 2011 - 10:07
k bro, can sms me the price? where does EL81 live? see if can collect and let betty wear the tube on sunday... Razz
