Babyboy's MBT ZTZ99
+3
7 posters
Babyboy's MBT ZTZ99
This is the Chinese modern MBT ZTZ99 tank. The box is big. Had a hard time coaxing the tank out from the box. It would not budge until a surgical cut to the box.
Nice long barrel
Item that comes with it
Bags of accessories
Rear lights install after casting done
Front lights
Some left over hot glue
Fine detailing. Very nice!
BB ball arming switch
Simple 3 page instructions for accessories
8 screws under the chassis holds down the top
Turret
Here's the problem that I had when rotating the turret. Cables caught within the gears area
Second area cable caught in the gears
Loose wire around turret gear that need fixing too
Removing 5 screws the turret pop out from the top chassis
Area to modify for barrel recoil. Lightly grease under the turret
Barrel elevation unit
Need to operate this later for barrel recoil
Marine grease before closing it back
Overall the Heng Long ZTZ99 is very nice. Next work will be the modification part. That's all for now. Thanks for watching.
Nice long barrel
Bags of accessories
Front lights
Turret
Re: Babyboy's MBT ZTZ99
Very big space inside the hull for more option parts.
The rear LED have to solder yourself?
Nice tank indeed!
Bro you better zip tie all the cables in one loom, instead of the way HL hot glued them in place. Funny the leopard isnt done this way...looks scarey!
No need tidying up as I think you will definitely mod the internals.
No. Come preassemble. Just need to plug the rear lights in the socket provided.RTECH wrote:Very big space inside the hull for more option parts.
Started to airbrush my ZTZ99... this is the furthers that I manage to go before the pump gave up on me... The pump stop after it got warm and slowed down and died after 10mins or so. Waited for it to cool down and try again. You can hear the electrical sound going thru the motor but its not turning at all.... I got hook on airbrushing so will continue with other cheaper alternative. Went stargek to get some air pressure can... Dun think a big can will last me for the entire project.
Oh no...babyboy wrote:Started to airbrush my ZTZ99... this is the furthers that I manage to go before the pump gave up on me... The pump stop after it got warm and slowed down and died after 10mins or so. Waited for it to cool down and try again. You can hear the electrical sound going thru the motor but its not turning at all..
Those cheap compressors can only be used for a short time, they are rated for "1/3 duty cycle", i.e. 10 minutes running, 20 minutes cooling.
Yeah. Now wonder if I need to get one with the airtank attach. Lesson learn.laneboysrc wrote:Oh no...babyboy wrote:Started to airbrush my ZTZ99... this is the furthers that I manage to go before the pump gave up on me... The pump stop after it got warm and slowed down and died after 10mins or so. Waited for it to cool down and try again. You can hear the electrical sound going thru the motor but its not turning at all..
First trial with air can. Very hard to control the pressure but am happy I got this far. Very hard work to prepare the stencil. My first so call Digital Camo. Need more improvement.
Left view
Top view
Right view
Left view
Top view
Right view
Testing TK22 and new gun flash. Using my phone to video.
Still got painting and some mod to the turret motor... Think you will finnish your setup by thanboolean21 wrote:When fixing up and poison us with a running video! ?
lets do a video together.
Nice sound !
Got some time yesterday... dismantle and cut out the airsoft unit as I will not be using it. Opening just nice for my gun barrel led flash to go thru. Will mod a servo elevation later on.
Need space so remove the FRS 7 speaker from the box and got a very tight fit. Why 2 speaker??? Cos the TK22 will take care of the machine gun, main gun, turret rotation and elevation while the TBS mini will handle the engine roaring sound. The TBS mini do have machine gun and main gun firing but have not explore there yet. Looks quite complex so I leave it first.
Next up will be video with full motion (minus the paint job... ). As the saying goes... till the next post. Thanks for watching.
laneboysrc wrote:Wahh! Major surgery going on
"Plastic" surgery.
Ha ha.. yeah, need to remove anything that is not in use to make space!
RTECH wrote:laneboysrc wrote:Wahh! Major surgery going on
"Plastic" surgery.
If its metal... will have a hard time cutting. Ha ha..
boolean21 wrote:Updates updates!!
Uploading Video.
Here's a start. Hope you guys like it and more bros will follow on
