[VIDEO] Fix stripped screw holes with brass knurled nuts
Hi everyone,
sometimes self-tapping screws that go into plastic wear out over time and strip. This can be easily repaired by using inexpensive threaded inserts, as I show in the video below:
You can get those inserts on eBay, AliExpress ...
You can search on the Internet for:
have fun fixing stuff, Werner
- Brass Knurl Nuts M3
- Set Inserts for Plastics
- Threaded Insert
Re: [VIDEO] Fix stripped screw holes with brass knurled nuts
Good stuff. Often, I will need to mod it with a Screw and nuts instead.
ongbenghui- Crawler
Great Info... as always. Thanks for sharing.
» Stripped DriveShaft screw
» [DIY Materials] Bolts, Nuts, Screws, Threaded Rods, Threadlock, etc etc...
» [DIY Materials] Metal brackets, rods, tubings, aluminium, brass, sheets, etc...
» WTB: M3 30mm Flat Head Hex Socket Tapping Screw
» [VIDEO] SGCrawlers Music Video RC Trucks Adventures Land Rover Defender Jeep Brute Wrangler
