In total there are 3 users online :: 0 Registered, 0 Hidden and 3 Guests :: 1 Bot
June 2019
3456789
10111213141516
17181920212223
24252627282930
3D printed 1/10 Scale Jerry Can
3D printed 1/10 Scale Jerry Can Empty 3D printed 1/10 Scale Jerry Can
Post by vertigo.blues on Sun 26 Jan 2014 - 14:43
Custom designed mount with Jerry can downloaded from thingiverse. Printed with ABS material.
http://www.vertigo-blues.com/110-scale-gas-tank-with-mounting-solution/
vertigo.blues
3D printed 1/10 Scale Jerry Can Empty Re: 3D printed 1/10 Scale Jerry Can
Post by boolean21 on Mon 27 Jan 2014 - 13:34
from your blog...
3D printed 1/10 Scale Jerry Can P1070975-1024x575
3D printed 1/10 Scale Jerry Can P1070977-1024x575
3D printed 1/10 Scale Jerry Can P1080032-1024x575
looks good!
saw from your blog that you are using the flashforge?
any first hand comments and reviews on the flashforge?
Post by RTECH on Mon 27 Jan 2014 - 17:22
Shocked amazing !
Post by Sabretooth_aw on Tue 28 Jan 2014 - 9:45
The options are endless with a 3d printer....
Sabretooth_aw
Sabretooth_aw
Post by vertigo.blues on Fri 31 Jan 2014 - 8:49
Boolean21,
Yup, i'm using flashforge and all i can say about this 3D printer is wow! Cheap and good, if you can do with its "cheapo design look", its definitely a buy! Performs as a well as makerbot dual extrusion model that cost 3K onwards. So far i've printed, i guess i have printed over 100hours of 3D design and its still working fantastic, no problems or whatsoever. Different material used for extrusion must have careful planning depending on the design of the print out. Large flat print out for ABS is tricky and tends to warp on the side even with heated bed, so some preparation on the bed is needed, i.e some hair spray or even spray adhesives(though may need to change kapton tape after the print). PLA is much easier to handle, large flat print outs, you just need a good tacky hairspray for bed preparation. I personally prefer PLA for print outs coz of its rigidity unless the print out is used outdoors for 24/7 or i need some flex on it , then i would go for ABS.
vertigo.blues
Post by boolean21 on Fri 31 Jan 2014 - 11:40
Thanks for the info bro!
Will need your advise more when i'm ready to get a 3d printer. Smile
Post by vertigo.blues on Mon 3 Feb 2014 - 22:01
No prob :)anytime! Just drop by my forum...for 3D printing discussion.
http://www.vertigo-blues.com/forum/viewforum.php?f=11
vertigo.blues
