In total there are 21 users online :: 0 Registered, 0 Hidden and 21 Guests
by CraftRC Yesterday at 20:14
mtr veri hot to touch.!!!
Post by singfah163 on Mon 27 Jan 2014 - 21:09
Gd day bro I newbe in crawler I have ax wraith .all part seem org.
why the motor feel hot I mean can burn type. ecs is warm batt is warm.
is the Motor ready to change . what will happen if continue to play will the mtr burn up.
as I always climb grass hill abt 45 to 65 degree angle.
if I was to change to 55t mtr will I need to upgrad the esc?
if I was to change to BL mtr let say 12t type will it be good on 2s as 3s the worm gear might not make it rite?
so I need any bro for advice tks?
michael
singfah163
Re: mtr veri hot to touch.!!!
btw is it ok to add micro fan on the mtr?
singfah163
Post by Liew on Mon 27 Jan 2014 - 22:47
Try down u pinion first.
If still hot maybe need high turn motor
Post by singfah163 on Mon 27 Jan 2014 - 22:52
btw the pinion how the sz sould I get down 16 or 12t.???
btw if use 55t mtr can the esc support.or must I use the specify mtr ecs just for 55t mtr
I mean brush esc.
singfah163
Post by Liew on Mon 27 Jan 2014 - 23:08
What esc motor pinion u using?
Post by singfah163 on Tue 28 Jan 2014 - 5:49
Brush esc fm ax.
singfah163
Post by Liew on Tue 28 Jan 2014 - 11:59
How many turn motor?
Pinion teeth?
Post by singfah163 on Tue 28 Jan 2014 - 18:10
Ok the mtr is 37turn brush mtr.I have change the pinon to 16t but still hot .
singfah163
Post by singfah163 on Tue 28 Jan 2014 - 18:11
I wonder anyone change to 11t .or lower.
the batt I use is 2s 1800amp 30c.
singfah163
Post by RTECH on Tue 28 Jan 2014 - 18:15
scratch axial wraith , worm gear??
Post by singfah163 on Tue 28 Jan 2014 - 18:35
U mean jam.but can craw up hill at 60 degree angle on rd didnt notice any funny noise
singfah163
Post by babyboy on Wed 29 Jan 2014 - 9:50
Hi. What bro RTECH is trying to say is Wraith do not use worm gear. Climbing hill all the time will make the motor hot. If you do have a Worm Gear... pls post a pic of the Wraith.
If you bought a second hand Wraith you need to check that the grease in the gear are still... greasy, else you need to re-grease it. I don't know if 11T or lower is recomended. If you are not going for crazy high speed a decent 27T or 35T motor is good enough for the Wraith.
Bring your crawler down during the SGcrawlers meet. It will make it a lot easier to advise you on your requirement and problem.
Post by RTECH on Wed 29 Jan 2014 - 16:54
A lot of factors can lead to motor overload. You got to bring down your crawler and let the SGcrawlers team analyse the problem.
Dun worry, its Free of charge.  Very Happy
