[TRANSMITTER MOD] HobbyKing HK310 AUX channel hacking - by LaneboysRC
Hey everyone! Me again
It turned out that modifying the HobbyKing HK310 transmitter in order to change the behavior of the AUX (CH3) channel is quite easy:
All documentation details and sample source code for Arduino and PIC microcontrollers can be found at https://github.com/laneboysrc/hk310-expansion.git
With the information found in this project you can modify a HobbyKing HK310 or a Turnigy X-3S transmitter to send arbitrary
information on the three channels to the receiver. This allows for example to:
Happy RC-ing!
- Change the AUX channel from a two position switch to a three position switch
- Change the AUX channel to an analog channel
- Perform custom mixing on any of the channels
- Transmit arbitrary data over the AUX channel to a custom decoder as to expand the system to a large number of on/off channels, e.g. to control lights and accessories on a scale RC truck
- Build your own custom transmitter by just reusing the wireless module
Happy RC-ing!
Re: [TRANSMITTER MOD] HobbyKing HK310 AUX channel hacking - by LaneboysRC
very cool!
great to have a 3-position 3rd channel on this radio!
not to mention having to control a full set of aux outputs using only one channel!
awesome work bro!!
awesome work bro!!
stickied this thread!
Electronic genius at work I must say...
Not easy if no knowledge of electronics. But interesting to know that it can be hack.
Seriously.... I need 1 of this. Wow didn't know a single channel can do so many wonders in the hands of circuitry guru.
Thanks for the kind words, guys!
I'd be happy to change the Tx to your needs. You know where to find me
babyboy wrote:Seriously.... I need 1 of this. Wow didn't know a single channel can do so many wonders in the hands of circuitry guru.
» Hobbyking Cessna 182 5 channel
» [TRANSMITTER MOD VIDEO] Flysky GT3B Hack PSX's Custom Firmware 0.61 How to hack? 8 channel 4-wheel steering Dual ESC Mixing
» Laneboysrc - DIY Light controller system
» LaneBoysRC's Tamiya MF01X Suzuki Jimny
» JoMac Comando Mach 3 transmitter from 1982
