[TRANSMITTER MOD] HobbyKing HK310 AUX channel hacking - by LaneboysRC
Post by laneboysrc on Sat 5 Apr 2014 - 15:44
Hey everyone! Me again  geek
It turned out that modifying the HobbyKing HK310 transmitter in order to change the behavior of the AUX (CH3) channel is quite easy:
All documentation details and sample source code for Arduino and PIC microcontrollers can be found at https://github.com/laneboysrc/hk310-expansion.git
With the information found in this project you can modify a HobbyKing HK310 or a Turnigy X-3S transmitter to send arbitrary
information on the three channels to the receiver. This allows for example to:
  • Change the AUX channel from a two position switch to a three position switch
  • Change the AUX channel to an analog channel
  • Perform custom mixing on any of the channels
  • Transmit arbitrary data over the AUX channel to a custom decoder as to expand the system to a large number of on/off channels, e.g. to control lights and accessories on a scale RC truck
  • Build your own custom transmitter by just reusing the wireless module
Happy RC-ing!
Re: [TRANSMITTER MOD] HobbyKing HK310 AUX channel hacking - by LaneboysRC
Post by boolean21 on Sat 5 Apr 2014 - 16:24
very cool!
great to have a 3-position 3rd channel on this radio!
not to mention having to control a full set of aux outputs using only one channel!
awesome work bro!!
Post by boolean21 on Sat 5 Apr 2014 - 16:41
stickied this thread!
Post by Zax13 on Sat 5 Apr 2014 - 17:53
Electronic genius at work I must say... Very Happy
Post by RTECH on Sun 6 Apr 2014 - 22:01
Not easy if no knowledge of electronics. But interesting to know that it can be hack.  Smile
Post by babyboy on Mon 7 Apr 2014 - 9:09
Seriously.... I need 1 of this. Wow didn't know a single channel can do so many wonders in the hands of circuitry guru.
Post by laneboysrc on Mon 7 Apr 2014 - 9:44
Thanks for the kind words, guys!
babyboy wrote:Seriously.... I need 1 of this. Wow didn't know a single channel can do so many wonders in the hands of circuitry guru.
I'd be happy to change the Tx to your needs. You know where to find me  Twisted Evil
