Boolean21's Poor man's wireless trailer lights for 1/14 scale Tamiya Flatbed Semi Trailer
Need some lights for the semi trailer....
So... finally manage to find time to fix it up....
Difficulty Level: 0 (easy! anyone can do it!)
Items used
1. Light kit with signal lamps - i used Hobbyking ones, but any light kit will work...
2. Extra receiver for on/ off trailer lights control as well as signal lamps, brake lamps, reverse lamps to work
3. Receiver controlled BEC - from HobbyKing, allows control of a switched power output via a spare channel
4. extra bits of wires...
5. Blu-tack - i used black ones.... i used it to hold the light buckets in position... i don't like permanent fixtures!
6. Light buckets / LED holders / etc - for the reverse lights... i used the spare ones from Axial kits...
7. switch - to switch off the receiver when not in use as i tapped the supply from the same AA batteries on the trailer
How it works?
Simple, channel 1 and 2 of the additional receiver is input to the light unit for the signal lamps, reverse lamps and brake lamps functions....
Receiver controlled BEC is to supply the input voltage to the light unit, so that when the trailer is not in use, we can switch it off using a spare channel on the radio....
That's it...
Some photos of the build....
The light kit from HobbyKing
Installed the LED and mocked up the light buckets from Axial kits...
but didn't use these light buckets in the end... used the round ones instead...
DIY-ed a bracket to hold the wires in place....
simply cut up a piece of styrene and drilled 2 holes for the bolts....
works well... simple...
zip-tied the cables, taped the light unit, bec, receiver to the underside of the trailer....
and taped the power switch for the receiver to the side of the ladder frame....
these won't be really visible unless you go take a shot of the trailer from below...
the back view.... used these axial light buckets instead...
done!
will try to do up a video of the light kit in action...
Items used
How it works?
That's it...
done!
Re: Boolean21's Poor man's wireless trailer lights for 1/14 scale Tamiya Flatbed Semi Trailer
Excellent project. The BEC with the switched output is neat. Keep on building stuff!
Nice! I see a boat there....
oceanic wrote:Nice nice!
laneboysrc wrote:Excellent project. The BEC with the switched output is neat. Keep on building stuff!
thanks bros!
yeah, the BEC with switched output is very useful... can use it for more other projects!
babyboy wrote:Nice! I see a boat there....
that's the toy boat that hasn't seen any water.....
bought it years back for a boat trailer project which haven't got started yet....
hi bro can futaba T8J use it for the 1/14 truck
kelvintan_hc- Crawler
kelvintan_hc wrote:hi bro can futaba T8J use it for the 1/14 truck
sorry bro... no idea about futaba T8J....
for the wireless lights, as long as you radio can pair to 2 receivers then it'll work...
» Boolean21's Tamiya 1/14 Flatbed Semi-trailer
» [VIDEO] Tamiya 1/14 Semi trucks Globe Liner Scania R620 MAN TGX 6x4 King Hauler dropbed flatbed trailer MFC-01
» [VIDEO] Tamiya 1/14 Semi trucks Ford Aeromax King Hauler Scania R620 container flatbed trailer MFC-01
» Zax13's Tamiya 3-axle reefer semi-trailer build
» Flatbed and container trailer
