Marpek's Second Kyosho HOR Build Thread
Hi all,
Posting here again with my new HOR kit built, after decommissioned the other bike for the past years... and also due to the recent vid of the Duratrax DXR500 which had excited me again to run bikes again!
First off... painting the parts tree...
main frame...
Assembly main frame with hopup damper...
Assembly of servo housing. Servo used slightly fatter and taller, thus some minor operation required to fit (note area under servo horn)..,
Assembly of HOR rider movement`s actuator...
Assembly of main frame and servo housing...
Next... drive train from donor bike (old Suzuki GSXR)...
Engine swap...
Rear suspension (I used original plastic to keep scale look)...
Front fork assembly...
Front and rear tires from Kyosho High Grip Tires set, without front weight...
It`s basically considering done at this stage, minus finishing off the rider, fairing and electronics...
Finishing pictures...
Outdoor pics...
Thanks for viewing!
main frame...
Engine swap...
Outdoor pics...
Thanks for viewing!
Re: Marpek's Second Kyosho HOR Build Thread
Thanks mate!
Swee! My advice is , keep it for display.
RTECH wrote:Swee! My advice is , keep it for display.
Yup... doing it rite now... but cant bear not to run it... just cruising around not racing can liao...
