Pininy Defender 110 camel trophy
Page 1 of 2
Page 1 of 2 • 1, 2
Starting a New project!
Re: Pininy Defender 110 camel trophy
Nice clean cut. Another D110
thanks guys..
was thinking of using Tamiya's plastic beams... 3mm square to make the roof rack, but i think it's too fragile - maybe 5mm would be a better options.. unless i get alum square hollow bars.. and construct
Make it light. Defender is top heavy.
Chassis is full alloy including the beadlock wheels... Very heavy!
Had some time... So decide to blog my build....
Making the roll bar and roof racks..
Got some metal shapes...hollow square brass... Would do the plastic one then will solder the brass....
Just finish my rack, still need to do the net and boards.....
Used up a pack of 3mm square rods!
Some experiments...
Using a fat drinking straw for the snorkel and a lexan sheet for the metal support tracks?
I can punch holes easily with a hole puncher lol!
Thanks!
Just completed the rack with latches and board....
And brackets for the lights and camel panel!
Thanks guys
Just finish the lights and panel for the roof rack....
Also thinking of the front window roll bar at 5mm maybe too thick thinking of using 3mm round bars... What do you guys think??
did some web surfing.. decided to do this mod.. as i don't want to always have to take out the body...
check this out...
now i just need to find the tiny door hinges ....
check this out...
boolean21 wrote:nice idea!
looking forward to the build updates!
Just ordered the door hinges... :-)
also here some picture of my roof lights.... and how i mount them screw under the brackets..
Here's what I've been up to... Make rear door for battery and also lights controllers on
Ordered the mini hinges... Hope they arrive soon..
Will install radiator fan and also will do a true steering mod :-)
Went shopping with my son, got some interesting parts from a electronic store...
Nice update. Cool ideas.
Some place for hiding light controllers and receiver under the seats...
Net looks like a prison ... Need to make thinner and wider ones...
stole some lego pieces from my son's toy box lol.
did a 180 degrees steering mod... not sure if the driver's hands and arms can articulate 360 lol...
easy mod... lego and some gears and shaft from mini-4wd
Steering mod expose lol! Simple design with 2 gears and a shaft for 180degrees, you can do 360 degrees or more by using another shaft and gears..
Just fitted the steering mod on the defender's dash....
Use a brass tube to run the shaft then mount the servo behind it..
here's a short test..
think the gearing too tight, will loosen it up..
On with the rear door....
Got some hardware from rotor hobby shop..
These plastic hinges are nice, will wait for the brass ones to compare the size..
Also got a door latch....too
awesome build
coldman28- Crawler
thanks!
just got the steering finally done. due to the size of the current servo... need to replace it with a small one, so got the corona's CS238MG.. they are pretty strong and tiny!
only one problem but can be fix, need to reverse the polarity on the servo manually. to sync up with the steering servo.
here's a test.. all in sync.
Page 1 of 2 • 1, 2
» [VIDEO] RC Land Rover Defender 110 Scale Camel Trophy landy Offroad Adventures
» [VIDEO] Scale RC Trucks Offroad Adventures MAN KAT1 Jeep TF2 hilux Defender 90 sniper scx10 Camel Trophy
» [VIDEO] Fun Trail! Scale RC Trucks Offroad Adventures MAN KAT1 Jeep TF2 hilux Defender 90 sniper scx10 Camel Trophy
» Which kit for Defender D90?
» Defender D110. Anyone has it?
Page 1 of 2
