Need help on BEC ???
Post by derrickwthip4 on Sun 30 Oct 2011 - 20:33
Hi saw some ppl servo connect to BEC confused
now to double check does RTR wraith need a BEC on the stock servo or just the stock ECS build in BEC good enough clown
In what situation than I need to use BEC.
what amp BEC should I use for the stock servo
If I'm use a XQ-S4120D 20kg High Voltage Digital Servo (7.4-8.4V 2S Lipo)
What amp BEC should I use confused
LHS do have CC BEC & UBEC so what are the different confused
Re: Need help on BEC ???
Post by RTECH on Sun 30 Oct 2011 - 20:55
derrickwthip4 wrote:Hi saw some ppl servo connect to BEC confused
It is better to use a BEC for crawler servo, in case the servo damage , it will protect the receiver. A 5Amp 6v BEC is enuff for normal 6V servo.
For Xq-S4120 HV servo no BEC require. You can connect the lipo bat directly to the brown and red color of the servo wires. The signal orange color wire connect to the receiver.And jump the servo brown to the rx negative.
I am thinking of getting tis servo too.
Post by derrickwthip4 on Sun 30 Oct 2011 - 21:08
Normally what are the price on the BEC u mention?
I already check the price for this XQ-S4120D 20kg High Voltage Digital Servo (7.4-8.4V 2S Lipo)
selling at $82, if buy online + shipping cost+BEC = near to the price of XQ-S4120D n no need BEC I thing I get it in our LHS cheers
Post by RTECH on Sun 30 Oct 2011 - 21:14
BEC rotor hobby selling cheap. Can't remember how much, i think less then $10.
Post by ShaiAX55 on Mon 31 Oct 2011 - 2:51
Hi, i used the XQS4120D on my AX10 and the XQS4013D on my Wraith, they works great. Smile
Post by derrickwthip4 on Mon 31 Oct 2011 - 2:57
I'm already add this item on my buying list tks for ur info Laughing
Post by RTECH on Mon 31 Oct 2011 - 22:55
ShaiAX55 wrote:Hi, i used the XQS4120D on my AX10 and the XQS4013D on my Wraith, they works great. Smile
Bro , can the XQS4120D submerge under water?
Post by derrickwthip4 on Mon 31 Oct 2011 - 23:00
Not sure leh but from the write out mention water proof check this link
http://www.jethobby.com.sg/cgi-bin/ezsite/prod/manager.cgi?action=show&pid=3044&cid=82&idx=1&gid=5
Post by RTECH on Mon 31 Oct 2011 - 23:08
Surprised Just got tis info from boopek. Those wiring the BEC to their servo.
Remember to short all negative wires togather to reduce interference and even power distribution to your component.
Post by RTECH on Mon 31 Oct 2011 - 23:11
derrickwthip4 wrote:Not sure leh but from the write out mention water proof check this link
Can see a lot of O rings but dunno can fully submerge. Did anyone try b4?
Post by boolean21 on Tue 1 Nov 2011 - 10:08
RTECH wrote:Surprised Just got tis info from boopek. Those wiring the BEC to their servo.
i wanted to draw out how i connected the BEC... but before drawing, managed to find one diagram of the BEC wiring... so saved my effort drawing... Smile
Basically, if you are using the BEC to power the rx and the servo, can just remove the red pin from the esc bec output wire before plugging into channel 2 of the rx
Then the external BEC input goes to your battery, output goes to the battery input of the rx... then servo just plug into channel 1 as per normal....
as easy as that, this is how i wired... Smile
Post by RTECH on Tue 1 Nov 2011 - 19:33
Surprised As for my case, i a bit kiasu. I use 2 BEC, one is the esc BEC and the other is the external BEC.
I connect the lipo directly to the external BEC, then the BEC out directly to the servo brown and red power wires.
The servo orange signal wire plug to the rx. This will work also. Then i link the external BEC black wire with the esc black wire (recomand by boopek). Anyway without joining the 2 negative black will also work, but may cause interference.
Why i do so troublesome is that i dun want the high power servo to share the same external BEC with the receiver.
If anything short circuit, i only wan half of the circuit to damage only. Although the current will flow thru the easlier path but still using the rx tracks as the path.
I dun want to use the rx pcb as a junction to transfer the high current.
If i use HV servo, i will just remove the external BEC and connect the lipo to the servo using hardwire.
Something like that....
My method is not necessary, I a bit kiasu. Haha...
Post by derrickwthip4 on Tue 8 Nov 2011 - 16:21
Hi I just bought a HobbyWing UBEC
1) 3A,Max 5A
Remark: As mention on manual (Output:5V/3A and 6V/3A switchable) so I should switch to 5V or 6V? (Using on my Wraith stock servo with NiMH 4200mAh 7.4v)
2)What's  the different between CC BEC & UBEC hope I not getting the wrong type of BEC!!!
Hope to receive some info tks :-)
Post by boolean21 on Tue 8 Nov 2011 - 17:45
derrickwthip4 wrote:Hi I just bought a HobbyWing UBEC
1) 3A,Max 5A
Hi bro,
both BEC and UBEC refers to the same thing.... BEC could be referring to linear BECs... and UBEC refers to switch mode BECs...
linear BEC is not efficient especially when using higher voltages to step down... generates a lot of heat....
switch mode BEC generate very little heat, very efficient stepping down of voltages... downside is it generate a lot of noise... as in RF noise... but not a big issue for us la... Smile
set the UBEC to 6V if your servo and Receiver can take 6V (should be able to... check the manual) for a little more torque for the servo... Smile
Post by derrickwthip4 on Tue 8 Nov 2011 - 19:20
Hey tks last QnA about the wiring connection check this link
http://helidirect.com/3a-5v6v-switch-mode-ubec-p-1449.hdx
Should I use the connection as mention on the manual, urs or Rtech ?
Post by RTECH on Tue 8 Nov 2011 - 20:12
Dun use my method, my one is not necessary and is complicated. The manual connection same as boo connection.
The swtiching BEC looks like comes with a noise reduction inductance coil liao.
Post by derrickwthip4 on Tue 8 Nov 2011 - 20:32
Don't worry bro if some things happen will not ask u to bear the responsibility joking only lol!
Ok come back to the QnA
Using manual method:-
1) BEC Out to receiver batt channel right?
2) Just disconnect the Red wire from the throttle channel right?
Post by RTECH on Tue 8 Nov 2011 - 20:39
derrickwthip4 wrote:Don't worry bro if some things happen will not ask u to bear the responsibility joking only lol!
Yup, the red and black pins on the rx are all same togather no matter which channel you plug.
Just be sure to remove that red wire from the esc, just plug in the black and signal(white or orange) into rx.
I just update the schematic for my connection above. Forget about the OSD/UAV in the schematic.
Post by derrickwthip4 on Fri 11 Nov 2011 - 14:39
Hi sorry what u mean jump the servo brown to the rx negative, is it connect another wire from servo to RX negative ???
Post by ket2175 on Sat 3 Dec 2011 - 21:21
Hi what if my rx dont have battery input , it only have AUX , throttle , steeling and bind/rs input. Like this the BEC output go to which one? AUX or Bind/rs.
My is spektrum SR3300T RX. Many thanks
Post by RTECH on Sun 4 Dec 2011 - 15:55
On the rx , the black and red pins are all the same for steering, throttle, AUX or bat.
Just make sure when you plug your BEC into the rx, the black and red wires is correct.
You can plug into any unuse socket.
For the bind socket , i am not sure whether can use. Anyone knows?
Post by ket2175 on Sun 4 Dec 2011 - 18:16
Ok noted , thanks so much.
