In total there are 13 users online :: 0 Registered, 0 Hidden and 13 Guests None
Futaba 4YF 2.4ghz
Futaba 4YF 2.4ghz
HI all, I just got myself a grand hauler with the MFC-03 and would like to seek some advise on the Futaba 4YF 2.4ghz transmitter.
I've replaced the right stick with springs and now it's the same as the Futaba 4YWD. But I was just wondering if there's any issues if the transmitter is a mode 1 or mode 2 type?
And also if the transmitter is a mode 1 type, would just plugging the MFC-03 plug into the 3rd channel of the receiver instead of the 2nd channel work?
Your advise is much appreciated. Thank you.
gtr206- Crawler
Re: Futaba 4YF 2.4ghz
Some function need certain input fr diff stick. U will have problem as the manual shows the setting is diff from what you have.
Thanks babyboy
I think my 4yf 2.4ghz is a mode 2 (throttle in right stick) Will you or anyone here knows how to change it to mode 1 (throttle in left stick)?
gtr206- Crawler
Oh my, sorry... I made a mistake. Yes you can. Its just a 4 channel radio. Does not matter mode 1 or 2.... it can be used. Just plug in the proper channel. Just need to check that the radio works with your MFC03.
Cheers.
Cheers.
that's great advise and thanks so much for your help babyboy...cheers!
gtr206- Crawler
» WTS: M11 2.4ghz tx and rx
» 3pks 2.4ghz tx
» 2.4Ghz radio system recommendation
» Wts Futaba ESC
» WTS FUTABA TX AND RX.
» 3pks 2.4ghz tx
» Wts Futaba ESC
