by boolean21 Today at 23:14
by boolean21 Today at 23:13
Axial AS-2 servo (Damaged)
Post by RTECH on Wed 2 Nov 2011 - 22:50
I manage to remove the silicone form the servo pcb.
As you can see ,the input wires turn black , burned and disconnected from the PCB.
One of the semiconductor crack into half (indicate by red arrow). The servo plastic casing very easily crack.
[img]%20Uploaded%20at%20ImageFra.me[/img]
Now the only parts that i can use are the gears and motor.
Wat cause the internal to blow up maybe , the the power supply to the motor and it dosen't move or too weak to move.
Re: Axial AS-2 servo (Damaged)
Post by boolean21 on Wed 2 Nov 2011 - 23:00
use it to make a servo winch!
