ESC AE5 Connector to Battery
Hi Guys,
I am new to the hobby and does not have enough knowledge on electronics. I do have an RR10 Bomber ESC AE5 with these type of connector.
And have 2 batteries (not the LiPo) with charger. The connectors are match.
Question, as I have problem or trouble plug-In the two connectors together "ESC AE5 & Battery" as they are different.
1. Can I modify the battery & charger connector to suit the ESC AE5 connector?
2. What do you call the other half of the ESC AE5 connector?
3. Where can I go to let it changed?
Appreciate any information/suggestions.
Thank you,
Wehlee
Thank you,
Wehlee
Last edited by boolean21 on Thu 17 Mar 2016 - 21:38; edited 1 time in total (Reason for editing : Edit: Embedded photo for you.)
Wehlee- Crawler
Re: ESC AE5 Connector to Battery
Hi,
somehow your photos do not show up, so it is difficult to give a correct reply.
According to Axial, the AE5 comes with a Tamiya-style connector (white color). This connector is pretty rubbish by today's standard, but works for a trail/crawler.
Your batteries could be Deans (usually red) or XT60 (yellow usually), see photo below for various types:
If you have Deans or XT60 I would recommend changing the ESC to a matching one. XT60 is quite good, Deans is ok but 2nd choice compared to the more modern XT60.
Small RC shops usually provide soldering services to change connectors.
If you don't mind traveling to Woodlands evenings or weekends I can also help you. Shoot me a PM.
cheers, Werner
cheers, Werner
and here's the link for the T-connectors / Deans from hobbyking
http://www.hobbyking.com/hobbyking/store/__11961__Nylon_T_Connectors_10_Pairs_20pc_.html
and the xt60 connectors
http://www.hobbyking.com/hobbyking/store/__9572__Nylon_XT60_Connectors_Male_Female_5_pairs_GENUINE.html
and bro Werner has amazing soldering skills....
Ok, the photos are now showing up for me.
The ESC connector is actually Deans (T-connector).
The battery/charger connector is Tamiya.
I'd recommend to change the battery/charger to Deans; or change all of them to XT60.
» Battery Connector mismatched
» Battery connectors help
» Where to get this led connector?
» WTS: Turnigy 5000mAh 6S 20C Lipo Pack w/4mm HXT Connector
» Is it Time to replace my Battery
