In total there are 22 users online :: 0 Registered, 0 Hidden and 22 Guests
by CraftRC Yesterday at 20:14
Discharge n Charge ???
Post by derrickwthip4 on Thu 24 Nov 2011 - 10:05
Hi I using this X-CHARGER606D to do my charging of my Nosram 4200mAh 7.2Volt NiMH battery.
Q1. What are the correct amp n voltage to set on my charger if I need to discharge n charge?
Q2. What would be the best number of cycle to do a discharge n charge?
Q3. Do I need to discharge n charge the batt every time I charging the batt?
Re: Discharge n Charge ???
Post by ket2175 on Thu 24 Nov 2011 - 10:13
Q1 If u want a faster charging time you can set 2 amp , but the punch not so strong . So if u set at 1 amp, it will take longer charging time. But the punch is much much stronger.
For discharge I will set 1 amp. Cause if u set the discharge amp to high it will spoilt your battery and also stress your charger.
Q2 If your battery has not been use for a long time, set to 2 cycle or maybe 3 cycle for best result.
Q3 Is better to discharge it first , then charge. As this can extend the battery life.
Hope this help.
Post by derrickwthip4 on Thu 24 Nov 2011 - 10:29
Hey tks again bro.
1)As my charger can set the amp n volt to do discharge, so now I set to 1A but what would be the correct voltage I need set for the cut-off,saw in some forum mention 5.4V .
2)As what I do now my batt 4200mAh I set to 4.2A its take about 1hrs10min to full charge is it ok or should I reduce the amp?
Post by boolean21 on Thu 24 Nov 2011 - 11:35
hi bro...
usually, charging will be at the battery cap rate...
e.g.
4200mah -> charge at 4.2A
3000mah -> charge at 3A
5000mah -> charge at 5A
etc....
remember to set the voltage right and the battery type right....
that's what i do.... hope it helps...
Post by derrickwthip4 on Thu 24 Nov 2011 - 11:37
Ok noted tks.
Post by boolean21 on Thu 24 Nov 2011 - 13:04
derrickwthip4 wrote:Ok noted tks.
ready to hit the trails? Smile
Post by derrickwthip4 on Thu 24 Nov 2011 - 14:06
Ya ya ya tat bo lay dah han leh coming weekend not free early Dec than joint Crying or Very sad
Post by boolean21 on Thu 24 Nov 2011 - 14:17
derrickwthip4 wrote:Ya ya ya tat bo lay dah han leh coming weekend not free early Dec than joint Crying or Very sad
see the photos i just posted.... the muddy wraiths! hahahha...
get ready for the mud in December? Very Happy
Post by derrickwthip4 on Thu 24 Nov 2011 - 15:59
Wa bro don't like that my wraith still very new leh please don't make so muddy mah heart pain u known Embarassed .
Post by ket2175 on Thu 24 Nov 2011 - 18:48
derrickwthip4 wrote:Wa bro don't like that my wraith still very new leh please don't make so muddy mah heart pain u known Embarassed .
Hope to see u this Sunday. Very Happy
