Discharge n Charge ???
Hi I using this X-CHARGER606D to do my charging of my Nosram 4200mAh 7.2Volt NiMH battery.
Q1. What are the correct amp n voltage to set on my charger if I need to discharge n charge?
Q2. What would be the best number of cycle to do a discharge n charge?
Q3. Do I need to discharge n charge the batt every time I charging the batt?
derrickwthip4- Crawler
Re: Discharge n Charge ???
Q1 If u want a faster charging time you can set 2 amp , but the punch not so strong . So if u set at 1 amp, it will take longer charging time. But the punch is much much stronger.
For discharge I will set 1 amp. Cause if u set the discharge amp to high it will spoilt your battery and also stress your charger.
Q2 If your battery has not been use for a long time, set to 2 cycle or maybe 3 cycle for best result.
Q3 Is better to discharge it first , then charge. As this can extend the battery life.
Hope this help.
Hope this help.
Hey tks again bro.
1)As my charger can set the amp n volt to do discharge, so now I set to 1A but what would be the correct voltage I need set for the cut-off,saw in some forum mention 5.4V .
2)As what I do now my batt 4200mAh I set to 4.2A its take about 1hrs10min to full charge is it ok or should I reduce the amp?
hi bro...
usually, charging will be at the battery cap rate...
e.g.
4200mah -> charge at 4.2A
3000mah -> charge at 3A
5000mah -> charge at 5A
etc....
remember to set the voltage right and the battery type right....
that's what i do.... hope it helps...
e.g.
etc....
Ya ya ya tat bo lay dah han leh coming weekend not free early Dec than joint
derrickwthip4 wrote:Ya ya ya tat bo lay dah han leh coming weekend not free early Dec than joint
see the photos i just posted.... the muddy wraiths! hahahha...
get ready for the mud in December?
Wa bro don't like that my wraith still very new leh please don't make so muddy mah heart pain u known .
derrickwthip4 wrote:Wa bro don't like that my wraith still very new leh please don't make so muddy mah heart pain u known .
Hope to see u this Sunday.
