3mm threaded rod to create links
Hi guys,
anyone know of SG shops where i get get some 3mm threaded rods? I need to shorten the links on my scx10 to get the wheelbase down for my Landy 90. I need 3mm so that i can re-use the stock plastic ends.
Thanks.
Thanks.
Evildrporkchop- Crawler
Re: 3mm threaded rod to create links
Wat the length u need if not to long u can use the 3mm screw just cut the screw head only
Evildrporkchop wrote:Hi guys,
Thanks.
hi bro,
can check out
Poey Huat Hardware
31 Kelantan Lane #01-20
Singapore 200031
Tel: 6294 8898
just called them up... they have 3mm threaded rod as well... in stainless steel...
anyone going down or pass by there? i need some 4mm threaded rods too...
thanks
how much 4mm u need?
Evildrporkchop wrote:thanks
you are going down to get them?
the threaded rods come in 1metre lengths...
i think i will get 2 lengths of 1metre... stainless steel ones...
will try and get down there tomorrow
better give them a call before going down as they close quite early...Evildrporkchop wrote:will try and get down there tomorrow
if convenient, would need your get to get 2 lengths of the 4mm threaded rods...
thanks bro...
Teck wrote:Wat the length u need if not to long u can use the 3mm screw just cut the screw head only
Teck - i need long lengths to create the lower and upper links on the SCX10.
Good suggestion for smaller links though
» [DIY] High Clearance links for AX10 using threaded rods
» Customize links on SCX10 for Defender D90 body
» SCX10 Honcho - Conversion of Rear 3 Link to 4 Links
» DIY SCX10 links
» Reinforcing the links of a standard RTR SCX10 Jeep Rubicon
» DIY SCX10 links
