3racing Winch Problem??? Help...Help...
Hey any ones using 3racing winch got problem!!!
My using Flysky GT3B Tx & Rx with 3rd channel.Every things wired up (winch unit power out to Y connector battery 7.2V NiMH, JST plug to winch n Futaba plug to receiver) & 3rd channel trim to zero when turn no the power the winch turn by it self when I press the 3rd channel button ones it turn other direction n press 2nd time it turn to normal direction??? I try to press the 3rd time should be stop,I hope but it cannot why???
I try pull out the Futaba plug n press the button on the winch control unit it work find than plug in the Futaba plug to 3rd channel again same problem !!! :-(
I also refer to the package it's mention suitable for (Futaba 4PK, KO PROPO EX/10 n Sektrum DX3R)
It mean Flysky Transimmter not compatible to this winch ???
derrickwthip4- Crawler
Re: 3racing Winch Problem??? Help...Help...
bro, it's not the winch problem...
the GT3B controller's 3rd channel is 2 position, not 3 position, so it will be either wind or unwind...
you can do like what i did, fabricate a simple relay to pulse the winch controller so that the gt3B can be used for the winch..
u can dig out the mod thread that i posted on how i did my relay...
actually u can also buy the receiver switch from hobbyking, and use that to mod and link to the winch controller.. easier than what i do...
Yo Boo.
How to do?? Can help me to do??
slow wrote:Yo Boo.
Bro, operate the winch manually, since you need to manually pull out the tow cable and hook to other vehicle. And you also manually need to pull the cable to let it wind back properly. May as well manually operate the winch. No points will be deducted.
Are you going to cross river with extra electronic stuff?
Aaa...if fix this winch just for fun n look a bit scale only n not prepare for competition :-)RTECH wrote:slow wrote:Yo Boo.
Just want to know is it not compatible with my transmitter ???
Tks for ur concerned :-)
that's why my winch got 3 methods of controlling...
using GT3b, using winch controller, using additional push button...
Ok understand now tks for all the info provided :-)
here's the thread on modding the 2 position 3rd channel on the GT3B to use the 3 racing winch...
https://sgcrawlers.forumotion.com/t67-using-a-radio-tx-with-2-position-3rd-channel-to-control-3-racing-winch?highlight=3+position
See already still . Me slow la
That's why i say just push the button on the winch controller can liao. Why make yourself so difficult?
So difficult to push that button on the winch controller meh?
boolean21 wrote:here's the thread on modding the 2 position 3rd channel on the GT3B to use the 3 racing winch...
Great :-) so the relay 1ps 6V I can get it from Sim Lim Tower right?
Tks a lot. I buy this winch cos of the Transimmter that come with 3rd channel must make full use of it meh He...He...
I also know press the button on the winch unit is not diffcul but still prefer on the TX 3rd channel button
derrickwthip4 wrote:boolean21 wrote:here's the thread on modding the 2 position 3rd channel on the GT3B to use the 3 racing winch...
yeah, relay can buy from SLT... I think use the hobbyking switch to mod easier... I try to find the part...
» Babyboy Drift 3Racing Sakura D4 AWD
» After market ESC problem...
» [RC F1 VIDEO] 3Racing F113 1:10 scale Formula 1 car brushless setup - test run at Woodlands Hardcourt
» Futaba t4vwd range problem
» Crawler gone wild weird ESC problem
