In total there are 5 users online :: 0 Registered, 0 Hidden and 5 Guests :: 1 BotNone
Most users ever online was 22 on Wed Apr 04, 2012 7:03 pm
» It has landed.....happy & Sadby angmohkia Today at 9:19 am
» Land Rover D90 Body
by angmohkia Today at 9:16 am
» New to crawler....
by angmohkia Today at 9:09 am
» Where to get Summit tires ?
by purexc Yesterday at 11:46 pm
by ironman Yesterday at 10:45 pm
» sc10 bashing.
by oceanic Yesterday at 10:23 pm
» Tower Hobbies first purchase requesting info
by SFXS Yesterday at 10:15 pm
» What a Rush
by SFXS Yesterday at 9:06 pm
» My racing rig
by SFXS Yesterday at 8:52 pm
» My new Kit Wraith
by RTECH Yesterday at 8:20 pm
» ShaiAX55 The Wreckluse Build
by oceanic Yesterday at 4:13 pm
» my wraith new look
by Teck Yesterday at 7:40 am
» Boolean21's Scania R620 - Restore...
by boolean21 Yesterday at 1:06 am
» WTS 7mth olds Tamiya Jeep wrangler CC-01 RTR
by boolean21 Yesterday at 1:01 am
» Behind the scenes....
by RTECH Mon May 14, 2012 7:09 pm
» my new mini collection
by Teck Mon May 14, 2012 12:59 pm
» Some question on wheel
by RJNG Sun May 13, 2012 5:29 pm
» [PHOTOS] Miscellaneous Trail Photos
by ironman Sun May 13, 2012 4:33 pm
» Wraith Rally 2
by oceanic Sat May 12, 2012 8:55 pm
» SGC Bike Team: RC Motorbikes thread!!!
by Marpek Sat May 12, 2012 11:16 am
derrickwthip4 Tamiya CC01 Build
Page 1 of 2 • Share •
Page 1 of 2 • 1, 2
My Tamiya CC01 Kit Build (Jeep Wrangler)
Hey have a look on my new project
Me not slow but Very very slow
Hmm... Slow mean fast & Fast mean slow ???
Will do update for my progress again Tks for viewing
Last edited by derrickwthip4 on Fri Feb 03, 2012 6:27 pm; edited 1 time in total (Reason for editing : typepo erorr)
derrickwthip4- Crawler
Re: derrickwthip4 Tamiya CC01 Build
Nice! Looking forward to more updates!
My RC Blog: http://MyHoncho.blogspot.com
RC Videos: http://youtube.com/MyHonchoSG
boolean21- Crawler
WOW
NICE C
Good paint Jod.. ..
Next time can help me to paint my project also????
NICE C
Good paint Jod.. ..
slow wrote:WOW![]()
NICE C
Good paint Jod.. ..![]()
Next time can help me to paint my project also????![]()
Alamak I knew u will say this.
boolean21 wrote:Nice! Looking forward to more updates!
Hey boo tks
slow wrote:WOW![]()
NICE C
Hey Boss I don't think I can help u very sorry cos very busy need to work,spend time with family,play RC toy, eat n sleep very busy leh
RTECH wrote:Derrick very good in handwork . His RC all nice and neat.
Hey tks for ur comments
ket2175 wrote:slow wrote:WOW![]()
NICE C
Wa I'm so lucky CEO OF Slow's RC museum like my paint job
Last edited by derrickwthip4 on Sat Feb 04, 2012 12:11 am; edited 1 time in total (Reason for editing : Typepo error)
Hi see my mob copycat from Marpek
Tks for viewing again
Derrick , looks like the whole rear shock is moving. Is the spring still with the shock or separate?
RTECH wrote:Derrick , looks like the whole rear shock is moving. Is the spring still with the shock or separate?
the whole rear shock with spring together with the shock will there be a problem when trailing need advice tks .
derrickwthip4 wrote:RTECH wrote:Derrick , looks like the whole rear shock is moving. Is the spring still with the shock or separate?
I have seen rockcrawlers doing this cantilever mod. it is actually a full droop suspension. But i am not sure when the belly is stuck , whether the the suspension drop able to push the truck or not since the spring is not working. Got to test and see.
RTECH wrote:derrickwthip4 wrote:RTECH wrote:Derrick , looks like the whole rear shock is moving. Is the spring still with the shock or separate?
Lets cross my finger that hope this mob work well
U can get 100mm shock from leadershobby only us4+ , cut the spring a bit , make it soft , then drill A hole mount the shock a bit front from original position !
Liew wrote:U can get 100mm shock from leadershobby only us4+ , cut the spring a bit , make it soft , then drill A hole mount the shock a bit front from original position !
Hey tks may consider this method
U mention drill a hole n mount the shock forward, the hole daimeter is it around 3mm for mounting the shock
When u shock is soft , u car weight will push down the shock , shock move forward will lower the chassis a bit . So it like 80mm shock but got extra 20mm travel . Adjustable shock easy way when u cut the spring .
Nice paintwork! Timw to get a landy for your CC01 bro and paint like god!!!
derrickwthip4 wrote:Liew wrote:U can get 100mm shock from leadershobby only us4+ , cut the spring a bit , make it soft , then drill A hole mount the shock a bit front from original position !
Hey tks may consider this methodJust nice my extra wraith stock shock length around 110mm will this method make the tire clearance n between the chassis gap bigger
U mention drill a hole n mount the shock forward, the hole daimeter is it around 3mm for mounting the shock![]()
honestly speaking, the stock shock is rather fine as long as you keep the weight low and when the rear articulate it will bite the ground...
when i use my brat hard shell, it performs pretty well as can do some rock crawling... with the heavier landy is another issue. for the drop mode even if you use a stick with no springs as shocks also can, cos it will drop anyway when clearing obstacles. If you want it to bite the ground, add tonnes of weight in the wheels even better i think, tho i havent teied that out yet!
Marpek wrote:derrickwthip4 wrote:Liew wrote:U can get 100mm shock from leadershobby only us4+ , cut the spring a bit , make it soft , then drill A hole mount the shock a bit front from original position !
Hey tks for sharing ur info to me ;-) don't mind I use ur method ;-)
Ok about My pain job not really perfect from far look like Flower but near like shit need to do some touch up with paint brush from some corner Ha...Ha...
Liew wrote:When u shock is soft , u car weight will push down the shock , shock move forward will lower the chassis a bit . So it like 80mm shock but got extra 20mm travel . Adjustable shock easy way when u cut the spring .
OIC tks
Hey have a look got update again
Don't judge a book by it's cover u know what's I mean
from far look's nice near like
Nice colour .......well done bro
coldman28- Crawler
Wah.. shiny shiny...
boolean21- Crawler
sori to hijack this thread.
my cc01 have this problem:
e front wheels r pointing straight when moving but point outwards when stationary.
ironman- Crawler
Is normal for stock steering !
Thanks bro!
ironman- Crawler
Page 1 of 2 • 1, 2
Similar topics» Xilisoft Video Converter Ultimate 7.0.1 build 1219
» tamiya ff03 pro
» Tamiya TA05-IFS R Chassis Kit
» Nieuwe Tamiya importeur in Nederland
» Te koop: Tamiya F104 PRO inclusief bandensets en reserveonderdelen (prijsverlaging!)
» tamiya ff03 pro
Page 1 of 2
