[Video] 10 Trucks Rock crawling Axial XR10 AX10 Losi Gmade R1 Mantis Slingshot Tuber Wraith
The Rigs: Axial XR10, Losi Comp Crawler, Gmade R1, Mantis, Ax10 Slingshot, 2x AX10 Tuber, Traxxas Summit, Axial Wraith, Tamiya CC01
10 Trucks
This week's adventure is on the rocks... Crawling at Little Guilin Singapore... the scenery is great and there's some nice rocks there..
Add us on facebook https://facebook.com/SGCrawlers
Visit us at http://SGCrawlers.co.nr and http://MyHoncho.blogspot.com for more info and videos.
Keep crawling!!!
Thanks for watching!
10 Trucks
Keep crawling!!!
Re: [Video] 10 Trucks Rock crawling Axial XR10 AX10 Losi Gmade R1 Mantis Slingshot Tuber Wraith
For the downhill, most of the rig rear end is too light. Throttle control should be consistant , jerking will cause the rear end to lift up because of the sudden brake.
Just some views , hope you all dun mind.
Yeah... Thats why I topped up on the gold bars.... Haha....
boolean21 wrote:Yeah... Thats why I topped up on the gold bars.... Haha....
Your rear wheel still put weighs? Because your rear axle oridi have a motor, if rear is too heavy have problem climbing uphill.
My rear end very light... Either I add weight... Or soften the rear shocks.... Cos if rear wheels, if one side lift too high, it'll like spring over and topple....
I tried with another pair of weight wheels, seems ok... But didnt try climbing though...
boolean21 wrote:My rear end very light... Either I add weight... Or soften the rear shocks.... Cos if rear wheels, if one side lift too high, it'll like spring over and topple....
You might wan to use thicker shock to eliminate the spring over effect.
Oh I see! Will try...RTECH wrote:boolean21 wrote:My rear end very light... Either I add weight... Or soften the rear shocks.... Cos if rear wheels, if one side lift too high, it'll like spring over and topple....
But the spring over is quite slow... Slowly tip over... will it work with thicker oil?
Should try my Summit on the down hill . Wasted
boolean21 wrote:Oh I see! Will try...RTECH wrote:boolean21 wrote:My rear end very light... Either I add weight... Or soften the rear shocks.... Cos if rear wheels, if one side lift too high, it'll like spring over and topple....
If it is slow you will have time to react. Use harder rear springs and soften your tires, your tires looks bouncy.
Yeah, the tires at too hard.. Need a softer set...
The box stock Xr10 oridi very competive. Just need to get a good sets of rock crawl tires.
I think in the video , those are hpi tires.
Nice vids..hope to join you guys for rock crawling soon..
awesome- Crawler
» [VIDEO] Rock Crawling at Little Guilin - XR10 AX10 Creeper Mantis M35A2 CC01 Rock Force Axial Wraith Honcho
» [Video] Rock Crawling at Little Guilin AX10 SCX10 Mantis Slingshot Gmade R1
» [ROCK CRAWLING VIDEO] Part 2: RC Rock Crawling at Little Guilin - Axial SCX10 Trail Finder 2 Hilux XR10 Wraith
» [VIDEO] RC Rock Crawling at Little Guilin - Axial XR10 SCX10 Losi Trail Finder 2 Hilux CR01
» [VIDEO] RC Rock Crawling Adventures at Little Guilin Axial XR10 Wraith Honcho Defender
