SGC Kyosho HOR bikes discussion
+6
10 posters
Page 5 of 6
Page 5 of 6 • 1, 2, 3, 4, 5, 6
Re: SGC Kyosho HOR bikes discussion
Very pro leh....
Saw the 1:1 chase 1:4 motard... Cute la...
Dunno whether appropriate to post or not leh...
boolean21 wrote:Very pro leh....
I think if wan to post must cover up the license plate.
Here is the link for some hop-up parts for the HOR.
http://www.stellamodels.com.hk/index.php?cPath=225_228_139
I just order some parts from this site, dunno reliable or not.
RTECH wrote:boolean21 wrote:Very pro leh....
Cover also dunno whether to post or not man... Hmm...
See how... Will try to do it soon...
Still haven't order the motard tyres.... Argh...
Pui pui pui...order liao then said bo jio!
I dunno reliable or not. I test water 1st mah. Pui !!
If i play 1/8th scale bike, i will definately get this:
http://2wheelhobbies.com/product_info.php?cPath=21&products_id=905
RTECH wrote:If i play 1/8th scale bike, i will definately get this:
Why not get the gpv-1 pro kit? Also have brake, maybe no motor but much cheaper!
Rtech, u think with front disc brake, motard tyres, can the vmx do wheel spin?
Furthermore, i dun like alu frame as cf frame the toughest strength to withstand crashes...
boolean21 wrote:Rtech, u think with front disc brake, motard tyres, can the vmx do wheel spin?
haha!!!!
Marpek wrote:boolean21 wrote:Rtech, u think with front disc brake, motard tyres, can the vmx do wheel spin?
haha!!!!
Yeah, really, if can, would be cool leh.... Still dragging cos dunno whether wanna order thr front disc brake together....
Haha...can also so back wheelie and slowly lans sidewards!
Marpek wrote:Haha...can also so back wheelie and slowly lans sidewards!
EatDirT- Crawler
EatDirT wrote:Marpek wrote:Haha...can also so back wheelie and slowly lans sidewards!
knn...my england so simple you dun understands meh? You loot, then jammed the front brake and back wheel wheelie lah...
like that hor... ur england so chim la thats why i nono wat u toking...pui pui kahahh puiiMarpek wrote:EatDirT wrote:Marpek wrote:Haha...can also so back wheelie and slowly lans sidewards!
next time speak propeli ok
EatDirT- Crawler
You class 2B nia thats way mah...
knn later we see who ride 2B pui...
EatDirT- Crawler
Marpek wrote:RTECH wrote:If i play 1/8th scale bike, i will definately get this:
Maybe, but definately not now.
boolean21 wrote:Marpek wrote:boolean21 wrote:Rtech, u think with front disc brake, motard tyres, can the vmx do wheel spin?
haha!!!!
Boo, the front brake is cable pull not hydraulic pistons. Can feel the braking but not until can jam the front wheel lah.
Somemore the front brake cable may affect the steering characteristic of the bike.
And the front wheel brake stunt need to transfer the rider weight to the front to make the front wheel grip the ground more, otherwise although the front wheel is brake jam but the bike will still move forward.
Then need another servo to tilt the rider to front when braking!
Hmm... then the front brakes mainly for what? Slow down and brake?
boolean21 wrote:Then need another servo to tilt the rider to front when braking!
Normally without the front brake, when your bike is at high speed and brake. The stopping distance is quite long. You need to brake early or else your bike will never brake in time.
With the front brake , the braking distance is shorter. You can wait until the last minute then brake. This gives you the advantage of fast in and fast out of the corner.
Oh I see! So still better to have la... :SRTECH wrote:boolean21 wrote:Then need another servo to tilt the rider to front when braking!
K, will decide soon...
My advice is you get the hang of your bike 1st before you add anything to it. Otherwise , there will be additional thing to deal with.
Adding additional servo to your bike will change the CG of your bike and affect the stability.
Braking to execute the corner is not necessary and may coz your bike to loose control.
Yes sir! Got it!
As for my hor, i use engine brake by setting epa for throttle to slow down the rear wheels b4 turning...
engine brake too much until engine breakdown hehe:P
EatDirT- Crawler
wah swee lei..very pro la u paint
EatDirT- Crawler
» Land Rover Defender 90 Discussion
» Need help on my 2 Kyosho HOR
» Kyosho Mini Z Motoracer
» Babyboy's Kyosho Honda NSR 500 HOR
» Himoto MX400 / NitroRCX MX400 discussion
Page 5 of 6
