In total there are 5 users online :: 1 Registered, 0 Hidden and 4 Guests :: 2 BotsMac Element
Most users ever online was 22 on Wed Apr 04, 2012 7:03 pm
» It has landed.....happy & Sadby angmohkia Today at 9:19 am
» Land Rover D90 Body
by angmohkia Today at 9:16 am
» New to crawler....
by angmohkia Today at 9:09 am
» Where to get Summit tires ?
by purexc Yesterday at 11:46 pm
by ironman Yesterday at 10:45 pm
» sc10 bashing.
by oceanic Yesterday at 10:23 pm
» Tower Hobbies first purchase requesting info
by SFXS Yesterday at 10:15 pm
» What a Rush
by SFXS Yesterday at 9:06 pm
» My racing rig
by SFXS Yesterday at 8:52 pm
» My new Kit Wraith
by RTECH Yesterday at 8:20 pm
» ShaiAX55 The Wreckluse Build
by oceanic Yesterday at 4:13 pm
» my wraith new look
by Teck Yesterday at 7:40 am
» Boolean21's Scania R620 - Restore...
by boolean21 Yesterday at 1:06 am
» WTS 7mth olds Tamiya Jeep wrangler CC-01 RTR
by boolean21 Yesterday at 1:01 am
» Behind the scenes....
by RTECH Mon May 14, 2012 7:09 pm
» my new mini collection
by Teck Mon May 14, 2012 12:59 pm
» Some question on wheel
by RJNG Sun May 13, 2012 5:29 pm
» [PHOTOS] Miscellaneous Trail Photos
by ironman Sun May 13, 2012 4:33 pm
» Wraith Rally 2
by oceanic Sat May 12, 2012 8:55 pm
» SGC Bike Team: RC Motorbikes thread!!!
by Marpek Sat May 12, 2012 11:16 am
SCX10 Honcho RTR Question
Page 1 of 1 • Share •
Hi Guys
Thanks to the great info provided by the guys here, on my questions about the Axial SCX10, I've decided to start with the RTR Honcho from Tower Hobbies
I plan to use the RTR to learn more about how these Hobby-Grade RC Rigs are setup, and also use it to spend some quality "fun family time" with my daughters (aged 7 and 10) who like playing with RC cars
I still intend to get the Builders Kit later on, but will use the RTR to lean more about how the SCX10 is setup. Can than use the RTR as a "guide" on setting up the Kit
What I would like to know is which stick battery pack and charger should I get for the RTR ? Are there local stores that sell these at reasonable prices, or should I just bundle a Battery with my order from Tower Hobbies ?
Thanks in advance
MANoj
Thanks in advance
MANoj
d12go4- Crawler
Re: SCX10 Honcho RTR Question
great choice to start with the honcho..
it's a great scaler out of the box... just need to DIY or buy some lower links for the rtr honcho and you are good to go..
if you plan to let the honcho swim... get nimh batteries as they are safe to be submerged...
locally, nimh cheapest would be around $30 each.. you can try getting them from tower if it's cheaper there since not much to top up for shipping if you get together with the honcho..
My RC Blog: http://MyHoncho.blogspot.com
RC Videos: http://youtube.com/MyHonchoSG
boolean21- Crawler
Thanks for the info Boolean21, really do appreciate your quick replies man
This one will, by and large, be a purely "fun-play" rig, for indoor fun and mild outdoor trailing around where I stay, so i don't plan to waterproof it....maybe I will join you guys on one of your "dry" trail runs later. When I get the Builders Kit later on, now waterproofing that will be one of my projects
Out of curiosity, are there any stock SCX10 in the bunch of cool rigs I see in your trailing Videos ? Or are they all modded ?
If an nimh costs about SGD $30 locally, I will bundle one with the Tower Hobbies purchase. Any advantage the Nimh has over Nicads ?
Also, on the Battery, having checked out a number of RC Forums, the common view seems to be that the standard Tamiya connector is not good, and should be changed to a Deans connector if possible. What are your thoughts on this ? Does connecting a Deans connector to the ESC require soldering ?
Cheers
MANoj
Cheers
MANoj
boolean21 wrote:great choice to start with the honcho..it's a great scaler out of the box... just need to DIY or buy some lower links for the rtr honcho and you are good to go..
d12go4- Crawler
If u dont plan on using it in water, then you can consider running lipo batteries...
Here's a stock rtr honcho in our recent videos...
I used to stick with tamiya plugs, but now, changed most of the plugs to deans...
Yes, u will need to solder it...
boolean21- Crawler
Wow.. now that is what I call Trail Ready
That looks to be the older TR Honcho, correct ? The new RTR Honchos are Silver, I believe.
With regards the battery, and advantage with the Lipo. And also, when I do get the Batery, is there a specific size I need, to fit the Honcho ? Or are all Stick batteries the sam size. Please pardon thses "Newbie" questons
MANoj
MANoj
boolean21 wrote:If u dont plan on using it in water, then you can consider running lipo batteries...
d12go4- Crawler
yeah, that honcho quite old liao... coming to first birthday liao... it's the AM tx rx batch... before the 2.4G tx rx days...
standard 7.2V stick packs nimh and the usual hardcase lipos can fit on the honcho without any problems...
you'll need a lipo capable charger if you wanna use lipo.
best is to get a charger that can charge all, i.e. lipo, nimh, nicad, etc....
so that you don't need to buy another charger in future when you wanna use different batteries..
d12go4 wrote:Wow.. now that is what I call Trail Ready
With regards the battery, and advantage with the Lipo. And also, when I do get the Batery, is there a specific size I need, to fit the Honcho ? Or are all Stick batteries the sam size. Please pardon thses "Newbie" questons![]()
MANojboolean21 wrote:If u dont plan on using it in water, then you can consider running lipo batteries...
boolean21- Crawler
Thanks for the info man.
Any recommended local Hobby Store for the Battery and Charger, or would getting it online be the better option ? Only issue I can think of, with getting online charger is whether it will work in Singapore.
Cheers
MANoj
Cheers
MANoj
boolean21 wrote:yeah, that honcho quite old liao... coming to first birthday liao... it's the AM tx rx batch... before the 2.4G tx rx days...
so that you don't need to buy another charger in future when you wanna use different batteries..d12go4 wrote:Wow.. now that is what I call Trail Ready
d12go4- Crawler
hi bro,
maybe u can post the link to the charger and batteries that you are looking at so that the other bros can comment on it..
US works on 110VAC and SG works on 240VAC, but nowadays, maybe power supplies come in large working voltage ranges, post the links here so that we can take a look at the specs. as long as the INPUT for the power supply to the charger is 240V, you are ok...
hmm... lipos tends to last longer and have more punch... but for trails, both are ok la.. nimh is good if you plan to "swim"... i use only nimh batteries when going swimming... during dry terrains, i use lipo some times...
when ordering from towerhobbies, remember to key in the discount code for additional usd75 discount for orders between usd300 - usd399...
d12go4 wrote:Thanks for the info man.
Cheers
MANojboolean21 wrote:yeah, that honcho quite old liao... coming to first birthday liao... it's the AM tx rx batch... before the 2.4G tx rx days...
boolean21- Crawler
Hi boolean21
Yah, will definitely be using the discount code
Ok Guys, hopefully you can help me to decide on the 6-cell 7.2V stick Battery and Charger I need to get for the RTR Honcho..... I plan to stick with Batteries that use the Tamiya Connector for now, as I don't have the know-how or equipment to be able to switch the stock Axial ESC to accept a Deans connector
When I was setting up my order for the Honcho at Tower Hobbies, the "recommended" battery and charger were these :
http://www3.towerhobbies.com/cgi-bin/wti0006p?&T=1&I=AXID9022&E=N
Is this recommended NiCd 6-Cell 7.2V 1500mAh Stick (with Tamiya connector) and AC/DC Peak Charger NiCd/NiMH ok ? I am especially concerned if the Charger will work in Singapore
One alternative stick battery that Tower Hobbies is suggesting is this one :
http://www3.towerhobbies.com/cgi-bin/wti0004p?&I=TOWC1030
This alternative battery is an NIMH (NOT NICD) and has a higher capacity.
I tried checking for Lipos, but honestly do not know which would work with the Honcho
Would it be better to order the Honcho from Tower Hobbies, wait for it to arrive..and than get the Battery and Charger from a Local Hobby Store ? This will probably cost more than bundling the Battery and charger with the order from Tower Hobbies, but this way I would be sure it can work on the Singapore current
If anyone here has recently ordered the RTR Honcho and bundled a Battery and Charger, I would really appreciate hearing which one you selected
Any advise would be greatly appreciated.
Cheers
MANoj
Cheers
MANoj
boolean21 wrote:hi bro,
d12go4- Crawler
Would still recommend nimh if using for honcho... If u are playing with water...
U can read this for conparison between nicd and nimh...
http://servocity.com/html/nicad_vs__nimh_batteries.html
Buy at least 2sets of at least 3000mah if going for nimh...
boolean21- Crawler
Hi boolean21,
Thanks for that link man, very informative.
Are there any local Hobby Stores you would recommend, that carry these Lipos, Nimhs and chargers ? For peace of mind (to ensure the charger will work in Singapore current), I think I would prefer to get it locally, even if it might cost more
Cheers
MANoj
Cheers
MANoj
boolean21 wrote:Would still recommend nimh if using for honcho... If u are playing with water...
d12go4- Crawler
Hi, current is not the issue, look out for the voltage input range.
Had sent u the shop that I bought from in the previous PM.
d12go4 wrote:Hi boolean21,
Are there any local Hobby Stores you would recommend, that carry these Lipos, Nimhs and chargers ? For peace of mind (to ensure the charger will work in Singapore current), I think I would prefer to get it locally, even if it might cost more![]()
Cheers
MANojboolean21 wrote:Would still recommend nimh if using for honcho... If u are playing with water...
boolean21- Crawler
Similar topics» Honcho Power
» question? am i...
» Question for HT-20 and HT-40 users....
» Question about score.
» Question ang Answer Portion :P
» question? am i...
