In total there are 9 users online :: 0 Registered, 0 Hidden and 9 Guests :: 1 Bot
May 2018
Gmade R1 Axles build
Post by boolean21 on Thu 15 Mar 2012 - 1:15
almost forgot i've got a set of gmade r1 axles on hand... Very Happy
finally, found some time today to build up the portal axles...
advantages of portal axles? the pumpkin is offset higher and it gives more clearance under the pumpkin...
well.. but for the monsterous terrains that we run our trucks... there's never enough clearance!! hahaha!!
planning to run these axles on my ax10 tuber... it had been lying upside down on it's roof for a few months already.... cos i used its axles on my landy.. Razz
here's some photos...
the axle housings are all plastic...
all non-hex bolts... all are phillip heads...
the gears look quite tough...
full ball bearings as usual...
and most importantly.... i marine greased the portal gears and stuffs before bolting up the axle...
finished building the axles except for the front knuckle arms...
overall, quality wise, not bad... everything fits nicely... except... i would prefer hex hardwares... and i love the metal pumpkin cover...
Re: Gmade R1 Axles build
Post by ket2175 on Thu 15 Mar 2012 - 9:44
Wow I like the axle chrome cover. Bling bling nice.
Post by boolean21 on Mon 19 Mar 2012 - 22:26
Measured the axles for bro ironman...
Hex to hex is around 22cm... Axial axles are around 19cm hex to hex...
So bro ironman... This axles might be a little wider than axial ones for your landy build...
Post by ironman on Mon 19 Mar 2012 - 23:54
Noted with many thx.
I'm eyeing on these axles tpgether with e gmade tranny as well..
Post by boolean21 on Tue 20 Mar 2012 - 0:05
ironman wrote:Noted with many thx.
I'm thinking of getting the r1 again.... now that my rc motocross might be on hold due to the cancelled mx400 order... might be getting it... see how.... Smile
faster build your landy! Smile
Post by boolean21 on Tue 20 Mar 2012 - 16:03
iron man... check this out...
http://www.rccrawler.com/forum/g-made-crawlers/279947-narrow-r1s.html
shortened R1 axles... Smile
Post by ironman on Tue 20 Mar 2012 - 18:05
looks e same leh.
nt much diff.
Post by boolean21 on Tue 20 Mar 2012 - 18:15
Huh... Got difference la bro... Smile
The above photos are yhe shortened axles.... Smile
Post by boolean21 on Wed 21 Mar 2012 - 9:59
ok, finished building the axles liao... ready to be mounted on the rig... Smile
will update in the rig's build thread.. Smile
