In total there are 21 users online :: 0 Registered, 0 Hidden and 21 Guests None
» Gaz-66 Military RC Truckby CraftRC Yesterday at 20:14
by ket2175 Tue 24 Apr 2018 - 18:31
boolean21 |
RTECH |
gionata78 |
laneboysrc |
oceanic |
Marpek |
babyboy |
Wrigleys |
ShaiAX55 |
Crawlers help! LED system
Page 1 of 1 • Share •
Bros i bought a LED system, do i jst plug into the batt in d receiver for my wraith? And the LED pcd cannot fit into the receiver box so fix it outside? Kumsia.
oceanic- Moderator
Re: Crawlers help! LED system
Check that the LED system you bought is 6v input, normally is 6v lah.
So just plug the jst into the receiver ,MAKE SURE THE RED IS + POSITIVE, BLACK IS - NEGATIVE.
The LED PCB can put outside but you must waterproof it with silicon if you go trailing and also prevent dust from damaging the PCB.
RTECH wrote:Check that the LED system you bought is 6v input, normally is 6v lah.
Thanks bro. Appreciate.
oceanic- Moderator
» Craigtone's System
» Blue's Bank event system
» Help!!! Electronics ??? For 1-10 crawler
» In-Hand Entertainment System
» ST-120 system in Costa Rica
