by CraftRC Fri 10 May 2019 - 15:10
May 2019
Need help making HPI Cyclone achieve 100mph!
Page 1 of 4 1, 2, 3, 4  Next
Need help making HPI Cyclone achieve 100mph! Empty Need help making HPI Cyclone achieve 100mph!
Post by Teck on Wed 25 Apr 2012 - 17:14
hi how to make my cyclone run 100mph
Wat the kv need fir motor?
Wat the esc needed?
Wat the cell needed for battery?
Need help making HPI Cyclone achieve 100mph! Empty Re: Need help making HPI Cyclone achieve 100mph!
Post by Marpek on Wed 25 Apr 2012 - 17:58
Bro...my advise is to buy the 100mph chassis la...so far 1/10 scale fastest around 120km/hr only...or less...
Post by Teck on Wed 25 Apr 2012 - 18:04
That chassis cost usd 1099 pale
Post by EatDirT on Wed 25 Apr 2012 - 18:09
teck not only that the pinon and spur gear also plays apart but remember dot to over gear the motor or u will burnt ur motor or esc..
eh ah pek u buy first la then we can play at tuas raceway...PUI PUI PUI
EatDirT
EatDirT
Post by Marpek on Wed 25 Apr 2012 - 18:15
Cyclone seems just too small fot the speed man...you cab lup the best equipment in, but will it handle?
Post by Marpek on Wed 25 Apr 2012 - 18:16
Post by EatDirT on Wed 25 Apr 2012 - 18:21
Marpek wrote:Cyclone seems just too small fot the speed man...you cab lup the best equipment in, but will it handle?
why cannot handlle?? teck only want to speed only nia not cup conner like ur HOR mah sure can want go stright only
rabbit
EatDirT
EatDirT
Post by Marpek on Wed 25 Apr 2012 - 18:29
Then you make one show me...hehe. hope the drivetrain can tahan the load.
Post by EatDirT on Wed 25 Apr 2012 - 18:32
Marpek wrote:Then you make one show me...hehe. hope the drivetrain can tahan the load.
not to forget ah pek now there is so many hop up from bearing to gear cheap cheap can buy 10 for u Laughing
EatDirT
EatDirT
Post by Marpek on Wed 25 Apr 2012 - 18:36
Ok lah... onz!
Post by Teck on Wed 25 Apr 2012 - 18:52
Haha eatdirt is right just want to try see can hit top speed a not not going to cup corner n thanks forgot about the gear problem so have to changer to high t pinion gear n small t spur gear right
Post by EatDirT on Wed 25 Apr 2012 - 18:58
ya teck but run time very short motor & esc sure will heat up..
teck put dry ice la to run cool heheh
EatDirT
EatDirT
Post by Teck on Wed 25 Apr 2012 - 19:06
Haha just a thought no body buying my cyclone so may as will make full use of it was thinking of putting heil motor n esc plus 6s battery to try cause heil esc can set for soft start think it will b better n can tah han the high heat if not worry
Post by Marpek on Wed 25 Apr 2012 - 19:22
Teck wrote:Haha eatdirt is right just want to try see can hit top speed a not not going to cup corner n thanks forgot about the gear problem so have to changer to high t pinion gear n small t spur gear right
Everything is designed for a purpose...i just feel even straight line cannot tahan liao...eg. the belts will break, shaft wobbles like mad...
Post by RTECH on Wed 25 Apr 2012 - 19:25
Teck wrote:Haha just a thought no body buying my cyclone so may as will make full use of it was thinking of putting heil motor n esc plus 6s battery to try cause heil esc can set for soft start think it will b better n can tah han the high heat if not worry
Why you sell your cyclone, i thought you use it for drifting? Dun waste your time setting the cyclone to run at 100mph. You are throwing your money into the drain.
Post by Marpek on Wed 25 Apr 2012 - 19:31
why you so late?
Post by Teck on Wed 25 Apr 2012 - 19:52
Haha rtech u tell to buy ota ma so i buy la Very Happy
Marpet u may b right but i just want to have fun with it Very Happy
Post by RTECH on Wed 25 Apr 2012 - 19:58
Teck wrote:Haha rtech u tell to buy ota ma so i buy la Very Happy
Then why you dun take my advice and buy ota in the 1st place?
Now you wasted your hard earn money on the cyclone.
Post by Teck on Wed 25 Apr 2012 - 20:15
Yes mum i learn my lesson Embarassed
But that time no ppl selling so buy 2nd choice low now buy also not late la so went u want to teach me drifting bounce
Post by RTECH on Wed 25 Apr 2012 - 20:27
Teck wrote:Yes mum i learn my lesson Embarassed
You can buy the cheap kit, since you buy the rtr cyclone also dun use the electronics at all.
Drifting i can tell you how to steer and throttle but you got to practice, practice and practice.
No shortcut.
Even now i still learning how to countersteer.
Post by Teck on Wed 25 Apr 2012 - 21:01
Have buy the streetjam ota-r31 rolling chassis that come with streetjam works aluminium damper> streetjam front one way> streetjam rear solid axle> streetjam counter steer pulley set (currently cs 1:47)now waiting for the electronic to come that y selling the cyclone
Post by boolean21 on Thu 26 Apr 2012 - 0:43
fierce la teck!!
Post by Teck on Thu 26 Apr 2012 - 7:24
Will is combo do the job running with 3s battery
http://www.hobbyking.com/hobbyking/store/%5F%5F22593%5F%5FHobbyking%5FX%5FCar%5FBrushless%5FPower%5FSystem%5F9200KV%5F100A.html
Post by Teck on Thu 26 Apr 2012 - 7:32
Yes Marpet have think of that too if the belt is not strong will make it 2 wheel drive for the shafts nite strong will use high torque servo
Post by boolean21 on Thu 26 Apr 2012 - 7:40
Teck is really determined!
Post by Teck on Thu 26 Apr 2012 - 8:41
I yo i thought who is asking the same question Very Happy
Post by Marpek on Thu 26 Apr 2012 - 8:48
Teck wrote:Yes Marpet have think of that too if the belt is not strong will make it 2 wheel drive for the shafts nite strong will use high torque servo
If you really so desperate, why not experiment on a F1 chassis where less drivetrain, use good tyres, custom some huge front and rear wing to create downforce for front traction...maybe can hit 300km/ hr!
Post by Teck on Thu 26 Apr 2012 - 9:08
Nola i not so desperate la just want to try something new n also see how fast a toy car can go
Post by boolean21 on Thu 26 Apr 2012 - 9:40
i'm interested to get a F1 chassis too leh... someday... when the MSCP goes into phase 2 upgrading.... Very Happy
Post by Marpek on Thu 26 Apr 2012 - 10:03
boolean21 wrote:i'm interested to get a F1 chassis too leh... someday... when the MSCP goes into phase 2 upgrading.... Very Happy
bigger mscp with rc track upgrading?
Actually, we can propose our useless govt to do something better for the community, like building rc tracks ontop mscp for example, like the bicycle track at pasir ris...so far i only knew 1 such track in sg heartland area. Ah Boo, use you SGC influence and power to talk to the TC.
