What 35T motor means?
Just wondering if 35T means the motor size is 350?
Thanks
Thanks
Re: What 35T motor means?
just the way the motor is built lah.
Higher the turns ( T ), more the torque less the speed.
350 is the motor physical size.. tamiya uses 540 for its 1/10 scales.
350 is smaller than 540.
Dieselx- Crawler
If you want speed, go for lower turns, if for trail or rock crawling, go for something like 55 T or more.
RJNG- Crawler
Yeah... T refers to the number of turns...
For trails... 27T or 35T are good... Still have some wheel speed which are nice for trails.
Oh OK. Cos I have an ESC that I bought for some project but not in use. The specs is for 380 motor. Its a crawler ESC from Thunder Tiger. Just wondering if this will work for the 35T motor that I bought from Tower Hobbies together with the SXC10 Kit. Hope that it won't burn out.
http://shop.rotor.com.sg/show-detail.asp?prodid={47BB9D61-FDE3-41BD-871F-C40968FE6432}&pn=2
Hmmm from the specs, it says max load 20A for 5mins, and 50A momentarily...
do you have the specs of the motor? Current consumption under load?
Might be a little risky... Although 35t doesn't draw high current... there might still be a chance of burning out the esc during binds....
If u have a amp meter, can try monitoring the current draw of the motor before using tge esc....
Another easier option, is to order the cheap ~usd10 china esc and waterproof it!
This is the motor that I got. Hope it is the correct one.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXWYE2#partsusage
Bro is esc is use for 1/18scale not 1/10 it will burn off if u use 540 motor better buy another esc for your 1/10 truckbabyboy wrote:Oh OK. Cos I have an ESC that I bought for some project but not in use. The specs is for 380 motor. Its a crawler ESC from Thunder Tiger. Just wondering if this will work for the 35T motor that I bought from Tower Hobbies toget
http://shop.rotor.com.sg/show-detail.asp?prodid={47BB9D61-FDE3-41BD-871F-C40968FE6432}&n=2
OK. Noted. Will look for other sources. Else will get the china ESC. Thanks all for the info.
» WTB 35T Motor
» looking for 45t 540 motor
» wtb:motor crawler
» WTB ESC for 35T motor for trailing.
» WTB: ESC for brushed 27T motor
» wtb:motor crawler
