September 2019
Understanding Gear Selections for 1/10 EP Car
Understanding Gear Selections for 1/10 EP Car Empty Understanding Gear Selections for 1/10 EP Car
Post by Wrigleys on Mon 21 May 2012 - 23:07
Came across this as I was doing some RC reading. Thought it would be useful to newbie like me.. Embarassed
Source: http://www.rcuniverse.com/forum/m_3255405/tm.htm
What is the best set-up for my truck? How fast will it go?
These are questions that have haunted me for nearly 10 years. I have been running 1/10 scale R/C trucks off and on, without a real good understanding of how to properly set it up. To me, it was FM ( friggin magic). What pinion should I use? What if I change the spur gear? It was all trial and error that resulted in several melted motors, blown ESC’s and damaged batteries.
But I have found the answer! And it is good!
Question 1: What size spur gear should I run? What about the pinion gear?
Well……. When selecting the spur gear and pinion gear size, you need to
understand that there is a direct ratio between the tire circumference (referred
to as roll-out) and the final drive ratio. That ratio, in most cases, should be
as should be as close to 1 to 1 as possible. 1 to 1? What? By a 1 to 1 ratio, I
am referring to one revolution of the tire to one revolution of the motor. In
doing so, we do our best to maintain the overall efficiency of the motor by
keeping it in the ‘Sweet Spot’. Here’s how it works. We’ll use my RC10T3 as the
example vehicle. The first thing to consider is the diameter of your tire. It is
used to calculate the roll-out of the tire. Multiply the diameter of the tire by
pi. ( Ex: 3.25”xpi=10.2101”) Now, you need to consider the final drive ratio of
your drive train. Begin by dividing the number of teeth on the spur gear by the
number of teeth on the pinion gear. This will give you your external drive
ratio. ( Ex: 87/19=4.5789). Now multiply your external drive ratio with your
transmission gear ratio ( Ex: 2.4x4.5789=10.9893 ). This is your final drive
ratio.
Now, what do we do with these numbers? Subtract the final drive ratio from the roll-out of the tire . (Ex: 10.2101-10.9893= -0.77926) Redo the calculation adding another tooth on the pinion : ( Ex: 87/20= 4.35 ( drive ratio )x2.4 ( transmission gear ratio )= 10.44 ( final drive ratio ) Then subtract the final drive ratio ( 10.44 ) from the roll-out ( 10.2101 )
( Ex: 10.2101-10.44= -0.230).
So, what is this formula telling us? In order to maintain the 1:1 ratio between
your roll-out and your final drive ratio, you need to select a gearing
combination that is as close to a 0 margin as possible. In this case, the -0.230
is the optimal choice, since it as close to 0 as we can get, without going over.
How do we know this works? We can check our overall efficiency by dividing the
roll-out by the final drive ratio. In this case, the 10.2101 roll-out, and the
10.44:1 final drive ratio means that we have less than a 3% total loss in
efficiency. In other words, the tire turns 0.977 times, for every 1 revolution
of the motor. Generally, it is best for your motor to gear your vehicle within a
+ or - 10% margin. ( In the case of this formula, +1 to -1 is an acceptable
margin.)
Overgearing a vehicle will add to the speed of the vehicle, but it does so at a
tremendous cost. The additional strain placed on the motor by the shorter
gearing, will cause tremendous heat build up as the motor struggles to reach its
peak RPM. Undergearing a vehicle can be just as damaging. Since the motor will
operate at it’s peak RPM almost exclusively, it will accelerate the wear of the
components and dramatically shorten it’s service life.
This formula works best with 1/10 scale vehicles running stock to mid-modified
motors. ( 27 turn to around 12 turn motors ).
However, hotter motors 12 turn and lower may require you to reduce the margin by
as much as -1 to combat heat build-up. But never gear your vehicle below an
overall efficiency of 90%.
We hav simplified this equasion, by adding a Gear Wizard Calculator. All you need to do is add the right entries, and the calculator does the math for you!
http://www.rcuniverse.com/community/gearwizard.cfm
Question 2: How fast will it go? Well, we have half the equation already. Using the circumference of the tire divide that by the final drive ratio. ( Ex: 10.2101/10.44=.977797) multiply that number by the maximum working rpm that your motor is capable of. Most motors are rated at XXX RPM, XXX rpm/volt, or XXXk/v. With the peak RPM rating, simply use that number, unless you are using a higher voltage cell. For RPM/v (k/v) you simply multiply its number of RPM/volt by the number of volts supplied to the motor. I have a Trinity Jade 15 turn motor. It is rated for 28,500 rpm. @ 7.2 volts. ( Ex: .977797*28500= 27,867.2145 inches per minute )
Convert that sum to feet per minute by dividing by 12 ( 12 inches in a foot) ( Ex: 27,867.2145 /12=2322.2678 feet per minute ). Now multiply your feet per minute by 60 minutes ( Ex: 2322.2678 *60= 139,336.0725 feet per hour ). Now divide your feet per hour by 5280 ( the number of feet in a mile ). ( Ex: 2322.2678 /5280= 26.389 miles per hour ). Keep in mind that this number is entirely theoretical and is affected by the age of your motor, condition and charge of your battery, friction and or slip from your tires etc. Despite this, it is a pretty good estimate of just how fast you can go with a given motor!
So, the key to speed and longevity is a high rpm motor coupled to a properly geared drive train. It will make for many a happy afternoon of backyard bashing with your truck!
GearWizard Rollout Calculator
All taken from quoted sources. Basketball
Understanding Gear Selections for 1/10 EP Car Empty Re: Understanding Gear Selections for 1/10 EP Car
Post by Liew on Mon 21 May 2012 - 23:39
Shocked Shocked
Post by Wrigleys on Mon 21 May 2012 - 23:47
I copy and paste one. Source quoted. Need pro to summarise.. bounce
Post by oceanic on Tue 22 May 2012 - 7:59
scratch Wah very chim.
Understanding Gear Selections for 1/10 EP Car Screen%20Shot%202015-01-22%20at%2012.58.42_zpstspekcmj
Post by Dieselx on Tue 22 May 2012 - 8:00
another personal tip from me when gearing is, when you have a choice of a pair of pinion & spur gears to get your ratio you wanted, for example :
P=10, S=90 ( ratio 1:9 )
or
P=15, S=135 ( also ratio 1:9 )
then go for the bigger numbers. P=15 and S=135
because mechanically it is more efficient for big gears to turn and also more gear cogs together at the same time too.. making a stronger transmission.
Dieselx
Post by boolean21 on Tue 22 May 2012 - 8:04
Thanks for sharing. Smile
Post by qks57 on Tue 22 May 2012 - 16:13
nice sharing! Smile
