wyetuck88's Land Rover Series 2 SWB build thread
Page 3 of 6 Previous  1, 2, 3, 4, 5, 6  Next
Re: wyetuck88's Land Rover Series 2 SWB build thread
Post by Liew on Mon 18 Jun 2012 - 21:36
wyetuck88 wrote:Haha,yeah six pack here i come!!!
you can try this place.
Wing Heng Iron Works Co. Pte Ltd
Address:
Kallang Basin Industrial Park #01-2634, 80 Geylang Bahru, (S)339688
Tel: 6292 1344
Look for ah hua.
Just need to draw out the dimension and tell him your design and he will be able to help you.
I think u are ah Hua , right ?
Btw I also want to welding small parts , is it ok ?
Post by boolean21 on Mon 18 Jun 2012 - 21:47
Looking good! Nice updates! Smile
Post by wyetuck88 on Mon 18 Jun 2012 - 22:03
Liew wrote: I think u are ah Hua , right ?
Shocked LOL haha what makes you think I am him?
Post by wyetuck88 on Mon 18 Jun 2012 - 22:04
boolean21 wrote:Looking good! Nice updates! Smile
Thanks!!!
Post by Teck on Tue 19 Jun 2012 - 1:50
Address:
Tel: 6292 1344
Look for ah hua.
Thanks a lot
Post by wyetuck88 on Tue 19 Jun 2012 - 16:46
currently thinking if I should do leaf spring or coil spring with 4 links?
leaf spring is a bit more work for me, it will look good but doesnt have much articulation as compared to coil springs with 4 links.
Does anyone have both coil spring and a leaf spring rig? which one preform better?
Post by wyetuck88 on Sat 30 Jun 2012 - 14:57
Teck wrote:
Thanks a lot
No Problem!!!
some Updates!!!
I have chosen to go with leaf springs, since the series ii land rover uses leafs springs.
Made some sketches and started on making them.
I bought a roll of chainsaw recoil spring from ebay.
cut to length heat them up and bend into shape with plier. You can also use springs from windscreen wiper
I think I will be using 3 leafs on the Front and 4 on the back
Made all four of them, the rear spring will be much stronger due to the weight of the body
Mock up of the leafs on the chassis. I will make the mounts next week, I think they turns out ok for a first attempt.
Bought the body to get it weld up too! I will not post up the name of the shop here, (but you can pm me if you need the shop help.)
I think I went at a wrong time when they are rushing to finish some other customer's work, everyone is a bit jumpy
and somehow the results came out not how I wanted it to be but I guess it will have to do for now, alignment on the left side of the
body and window panel is off, and there are gaps between the roof and window panel.
The body is now 60% finished and it still need more works, need to redo some parts.
I hope you like it! Thanks for reading Very Happy
Post by boolean21 on Sat 30 Jun 2012 - 14:59
Looks good!
Post by laneboysrc on Sat 30 Jun 2012 - 19:21
My deepest respect, this looks absolutely awesome! Thanks for sharing and please keep doing so!
Post by wyetuck88 on Sat 30 Jun 2012 - 22:14
boolean21 wrote:Looks good!
Thanks!
laneboysrc wrote:My deepest respect, this looks absolutely awesome! Thanks for sharing and please keep doing so!
Thank you sir! Very Happy
still deciding on the ride height.
Anyway I was shocked by the price of a transfer gearbox on ebay...USD76 not including
shipping!!! Its was way out of my budget. I think I will build my own transfer gear.
Post by RTECH on Sun 1 Jul 2012 - 10:19
Smile Wow, you really got the time and patience to built all these. And you have good "hand job" . Can't wait to see your final product.
Post by boolean21 on Sun 1 Jul 2012 - 14:12
looking forward to more updates man... Smile
Yeah, t cases are ex... Build build build!
Post by wyetuck88 on Mon 2 Jul 2012 - 22:03
RTECH wrote: Smile Wow, you really got the time and patience to built all these. And you have good "hand job" . Can't wait to see your final product.
Thanks!!!
Post by wyetuck88 on Mon 2 Jul 2012 - 22:05
boolean21 wrote:looking forward to more updates man... Smile
anyway where do you guys get your styrene supplies from? I saw in art friend, $9 plus for a piece 300x400mm? Shocked Shocked Shocked damn thats expensive.
Post by boolean21 on Mon 2 Jul 2012 - 22:14
Check the thread in diy section, I posted the address for the styrene...
Post by wyetuck88 on Tue 3 Jul 2012 - 21:13
orh ok. anyway I am facing lots of problem with leafs, they kept breaking at the mounting holes that is used to screw on to the axial axle. Also U bolts are hard to make for axial axle too, as they are a kind of square and round shape contour. I think I am going to take the easy way out and use springs instead.
Post by boolean21 on Tue 3 Jul 2012 - 21:23
Why not use m3 threaded rods to make the u bolts?
No choice la, yours is HEAVY METAL... Very Happy
Post by wyetuck88 on Tue 3 Jul 2012 - 21:54
problem is its hard to make the m3 thread follow the contour of the axial axle...Either i grind away the extra material to make it a square and make square U bolts or I have to get new axle... Very Happy
Post by boolean21 on Thu 5 Jul 2012 - 12:16
Hi bro, managed to find some pictures of what I meant... Smile
Post by wyetuck88 on Fri 6 Jul 2012 - 1:22
I know what you mean If I do that I got to remove this extra material at the shock mount. Not only it will affect the structure but also affect the value of the axial if I decided to sell my crawler one day Shocked
Post by boolean21 on Fri 6 Jul 2012 - 1:31
wyetuck88 wrote:I know what you mean If I do that I got to remove this extra material at the shock mount. Not only it will affect the structure but also affect the value of the axial if I decided to sell my crawler one day Shocked
hahah,.. i see i see...
Very Happy
looking forward to more updates! Smile
Post by oceanic on Fri 6 Jul 2012 - 7:53
Can't wait for u to get on trail bro.
So we can cook combat ration on your mess tin Twisted Evil
Post by wyetuck88 on Sat 7 Jul 2012 - 0:26
oceanic wrote:Can't wait for u to get on trail bro.
LOL...Its gonna be a long build, got to wait a bit more...
Anyway some small updates...
Done nothing much except mounting the axle to the frame...Took the
easy way out and use shocks.
Post by boolean21 on Sat 7 Jul 2012 - 0:47
Looks good! Smile
Post by laneboysrc on Sat 7 Jul 2012 - 7:29
Very beautiful! Even with front motor just like the real one.
Post by wyetuck88 on Sat 7 Jul 2012 - 12:08
boolean21 wrote:Looks good! Smile
laneboysrc wrote:Very beautiful! Even with front motor just like the real one.
Thanks!!! and laneboysrc yours nicely done too!
the suspension mount are temporarily gonna made one from brass soon.
Post by wyetuck88 on Thu 12 Jul 2012 - 0:17
Not much updates, just some mock up pictures. Body is covered with putty
still got alot more work to be done.
Thanks for reading.
Post by boolean21 on Thu 12 Jul 2012 - 0:21
What putty are you using?
Post by wyetuck88 on Thu 12 Jul 2012 - 0:24
Those workshop using those car panel repair kind of putty loh. Very Happy
