In total there are 13 users online :: 0 Registered, 0 Hidden and 13 Guests
wyetuck88's Land Rover Series 2 SWB build thread
Page 4 of 6 Previous  1, 2, 3, 4, 5, 6  Next
Re: wyetuck88's Land Rover Series 2 SWB build thread
Post by boolean21 on Thu 12 Jul 2012 - 0:25
wyetuck88 wrote:Those workshop using those car panel repair kind of putty loh. Very Happy
Where you bought ah?
Post by wyetuck88 on Thu 12 Jul 2012 - 0:29
Those hardware shop loh. $6 cheap cheap 500gram, can last a long long time. Very Happy
Post by boolean21 on Thu 12 Jul 2012 - 0:32
Can post a photo of it?
Can't find it leh, is it polyester based type?
Thanks. Smile
Post by wyetuck88 on Thu 12 Jul 2012 - 0:45
boolean21 wrote:Can post a photo of it?
Thanks. Smile
NP:)
Post by boolean21 on Thu 12 Jul 2012 - 0:48
Thanks! Smile
Post by wyetuck88 on Thu 12 Jul 2012 - 0:53
boolean21 wrote:Thanks! Smile
no problem!!!
Post by boolean21 on Thu 12 Jul 2012 - 0:56
np! hey does the body looks alright to you? any comments? I can take critics. Laughing
Yeah, looking good... Smile
It might turn out bigger than our defenders though..
Whats the size of this baby?
Post by wyetuck88 on Thu 12 Jul 2012 - 1:09
33cm tall 53.5cm long and 23.5cm wide. whats the measurement or your D90 defender?
Post by boolean21 on Thu 12 Jul 2012 - 9:08
The defender plastic body meadures around 41cm long x 21cm wide.
Think still ok la... Cos your body width close to ours, when lined up, should look fine. Smile
No worries about it . Smile
Burn more, oil! Very Happy
Post by RTECH on Thu 12 Jul 2012 - 19:17
Very Happy I think you have to use auto paint for your landy liao.
Post by wyetuck88 on Fri 13 Jul 2012 - 11:07
RTECH wrote: Very Happy I think you have to use auto paint for your landy liao.
Kk thanks boo. Rtech see how it goes, auto paint very ex.
Post by wyetuck88 on Wed 18 Jul 2012 - 0:28
Its been a while since the last update.
Done nothing much but trying to make an interior for the series II
went back to the drawing board and decided to go the leaf spring route.
Only did the front, the rear is coming soon.
The ride height is off, axial length is off. As the tires are half outside the wing, there is nothing much I can do. If I mount the ride height low, every obstacles is going to cause the tires to rub against the wing. I havent seen any Series II with fenders yet so I cant put fenders on the body. Actually There wasnt any scale to begin with, The whole body is based on this picture I found online lol.
should Have based on a series II blueprint. But Nvm, hey first attempt so lesson learned.
I am too lazy to build up the transfer gear, so planning to put a axial transmission
gear and call it done.
Post by boolean21 on Wed 18 Jul 2012 - 0:36
you can bend metal very nicely! Very Happy
looks like it will be rolling soon!
Post by wyetuck88 on Wed 18 Jul 2012 - 1:02
boolean21 wrote:you can bend metal very nicely! Very Happy
nah its the machine that do all the bending. I only do the dimension and cutting only.
Post by laneboysrc on Wed 18 Jul 2012 - 7:16
Wow, very impressive metal-origami!
I think you shouldn't worry too much about exact scale appearance regarding tire clearance etc. As you said if you make it exactly look scale, it will not work well on trails. Nature is not 1:10 in most places lol!
Post by wyetuck88 on Thu 19 Jul 2012 - 21:32
haha you are right!!! thanks!
Post by wyetuck88 on Thu 26 Jul 2012 - 23:37
some update.
mounted the motor and transfer gear, so the chassis is fully functional as of now.
used a axial transmission for the transfer gear...I am too lazy to built one from scratch
Thats all for now.
Post by boolean21 on Thu 26 Jul 2012 - 23:56
Any tips on how to split the square tube into straight halves?
Post by wyetuck88 on Fri 27 Jul 2012 - 0:08
boolean21 wrote:Any tips on how to split the square tube into straight halves?
I cut my square rod using a angle grinder . I drew a line through the centre of the rod for guiding my cut. You can use a jig saw or a hacksaw (but it will be a bit slower). Hope it helps!
Post by boolean21 on Fri 27 Jul 2012 - 0:14
Will try to get a set of angle grinder.... Hacksaw seems like difficult to split them equally... Very Happy
Post by wyetuck88 on Fri 27 Jul 2012 - 0:24
boolean21 wrote:Will try to get a set of angle grinder.... Hacksaw seems like difficult to split them equally... Very Happy
Hack saw can also but have to do it slowly.
Post by wyetuck88 on Fri 3 Aug 2012 - 0:02
some minor update.
Been working on the body lately, the chassis is completed, now left welding up a few
more small bits and adding details to the body. Hopefully I am able to join you guys next week.
body shots
working on the steering.
Thats all for now.
thanks for reading, hope you guys like it.
Post by boolean21 on Fri 3 Aug 2012 - 0:06
looking good! Smile
see if you can make it in time for the NDP trail next thursday! Smile
Post by wyetuck88 on Fri 3 Aug 2012 - 0:09
wah ndp trail...what time? hope I can just come along even if my truck is not done yet!
Post by boolean21 on Fri 3 Aug 2012 - 0:16
wyetuck88 wrote:wah ndp trail...what time? hope I can just come along even if my truck is not done yet!
Yes, do come along even if your truck is not ready. It gives us an excuse to bring a spare truck Smile
Likely to be 9am. Wait for boss harakiri's announcement. Smile
Post by wyetuck88 on Fri 3 Aug 2012 - 0:20
ok but I gotta leave by 1230 is it possible? haha.
Post by RJNG on Fri 3 Aug 2012 - 11:09
Absolutely amazing work, well done! Two thumbs up for you man.
RJNG
Post by wyetuck88 on Fri 3 Aug 2012 - 14:27
Thank you for your kind words! Hope I can come to the trail with you guys soon!
Post by wyetuck88 on Mon 13 Aug 2012 - 0:23
some updates!
Shot of the undercarriage, I quite like this shot!
Shot of seats and chassis.
Shot of the whole undercarriage
Engine bay
Engine bay
started on the roof
Interior, The welds are fulgy, but I think it ok cause no one will want to look inside.
mount my servo behind the dash o I have Working steering, the long threaded rod is for the steering wheel.
some more repeated shots.
made the windscreen, awaiting to glue in the "windows"
Shot at 2012-08-12
Landy is almost done waiting for my battries and my esc and its ready to roll ...now need a coat of paint and some more details to add in.
fuel tank cap, doors and door handles to be cut out, amber lights, reverse lights, inner fenders, rear bumper, and lots more.
Thank for reading, I hope you like it. see you guys on the trail soon.
Post by boolean21 on Mon 13 Aug 2012 - 0:36
looks good... everything is taking shape nicely... Smile
btw, how much do they charge for welding and bending?
