In total there are 14 users online :: 0 Registered, 0 Hidden and 14 Guests :: 1 Bot
Boolean21's 1/10 M923 - 5 ton truck - Newbie try to scratch build a truck body... :D
Page 6 of 6 Previous  1, 2, 3, 4, 5, 6
Re: Boolean21's 1/10 M923 - 5 ton truck - Newbie try to scratch build a truck body... :D
Post by dwong on Thu 2 Aug 2012 - 17:18
Hmm...... at least RTECH is honest... not like Oceanic....... trying to act decent...... chey!!!
Honestly.... we should start to recruit some Ladies in our trailing session..... it will be more funnnnnnnnn............ hee hee heee........ Twisted Evil
dwong
Post by RTECH on Thu 2 Aug 2012 - 20:09
Shocked Did i heard ladies?! I'll BE BACK ! Razz
Post by boolean21 on Sun 5 Aug 2012 - 1:23
some minor updates...
wanna make an anti-roll bar for the m923 at first, but decided to make a suspension limiter first, will can be modded into an anti-roll bar if required....
with this installed... it'll limit the up-travel of the wheels so that the tires wont rub against the fenders when crawling over obstacles... Smile
Seats secured and driver in position.... ready for an offroad test drive.. Smile
Post by RTECH on Sun 5 Aug 2012 - 11:05
Eh... I think rigid axle no need roll bar. You can also limit the suspension travel by intalling spacer inside the shock piston shaft or inserting O rings outside the shock shaft.
Post by boolean21 on Sun 5 Aug 2012 - 12:36
RTECH wrote:Eh... I think rigid axle no need roll bar. You can also limit the suspension travel by intalling spacer inside the shock piston shaft or inserting O rings outside the shock shaft.
Need anti roll bar... Razz cos mine rolling too badly liao...
Adding spacer cant work for my case, cos shocks are mounted an angle... At the max tire travel, thre shock not at the max travel position... So have to use this... Else putting spacer easier... Smile
later trying out if got time... Smile
Post by RTECH on Sun 5 Aug 2012 - 19:07
Rolling Eyes Just now saw your truck roll too much. I think the chassis too heavy liao.
Can see the front tyre compress until flat. Last time liew's 3 tonner truck also roll too much. Maybe you have to search for more harder springs.
Post by boolean21 on Sun 5 Aug 2012 - 19:13
RTECH wrote: Rolling Eyes Just now saw your truck roll too much. I think the chassis too heavy liao.
Yeah.. she's heavy... Very Happy especially with the df03ra on the bed... Very Happy
Will convert the shock limiter in the front to anti roll bar soon... Very Happy
Tyres no choice... Cos the ripsaws are nice and soft. Very Happy
I think if put teck's pitbull 2.2 tires.... Will be totally punctured look... Very Happy
Post by wyetuck88 on Sun 5 Aug 2012 - 22:31
boo how heavy is your truck now?
Post by boolean21 on Sun 5 Aug 2012 - 22:55
wyetuck88 wrote:boo how heavy is your truck now?
just weighed for you.. Very Happy
around 6kg+ ... without batteries.. Razz
slightly more than a pack of rice.. Very Happy
Post by boolean21 on Sun 5 Aug 2012 - 23:00
some photos updates....
need a lift? Very Happy
the M923's first dirt session....at DIOT....
Post by wyetuck88 on Sun 5 Aug 2012 - 23:08
wah really nice!!! is the transmission ok? any problem trailing today? I cant wait for the video...need to weigh mine too.
just weigh also, its 4plus kg without battery and electronics. I think because you got 3 axles...
Post by boolean21 on Sun 5 Aug 2012 - 23:11
wyetuck88 wrote:wah really nice!!! is the transmission ok? any problem trailing today? I cant wait for the video...need to weigh mine too.
thanks bro...
haven't go trail yet... only did some trial runs beside DIOT....
looking forward to bring it to chestnut.. Very Happy
but i won't force it too hard... will go easy on this truck... Razz should be fine i hope... (fingers crossed) Very Happy
Post by laneboysrc on Mon 6 Aug 2012 - 8:42
It is very hard to see in the photos just how big it is -- until you see a humongous Tamiya Truck on the back of this even larger vehicle. Shocked
I am very keen to see how this thing moves on the trail. All that weight should make it look more realistic than the flimsy Lexan vehicles.
Do you have a record of how much time you've spent on the body so far?
Post by boolean21 on Mon 6 Aug 2012 - 9:55
laneboysrc wrote:It is very hard to see in the photos just how big it is -- until you see a humongous Tamiya Truck on the back of this even larger vehicle. Shocked
no bro.. didn't record the time spent till date...
but really did burned lots of midnight oil... Very Happy
Post by RTECH on Mon 6 Aug 2012 - 17:10
Surprised The trucks looks great on the sandy area. Machiam like going for mission "desert storm".
Post by boolean21 on Tue 7 Aug 2012 - 23:22
Some photos taken at Punggol End...
And a short video of the M923's test run at Punggol End...
Thanks for watching... Smile
Link - https://www.youtube.com/watch?v=9AMSgdvBhSs
Post by wyetuck88 on Wed 8 Aug 2012 - 1:43
looks good!!!! If you think your body roll is bad...you havent seen mine!!! I dun think my car would even budge at all...
Post by Huggable on Wed 8 Aug 2012 - 23:07
Excellent effort! Liked the welding of the handles, and the use of balloon base for the dashboard dials.
How about adding a pair of wing mirrors to complete the look?
boolean21 wrote:Some photos taken at Punggol End...
Huggable
Post by boolean21 on Thu 9 Aug 2012 - 1:07
wyetuck88 wrote:looks good!!!! If you think your body roll is bad...you havent seen mine!!! I dun think my car would even budge at all...
thanks bro... still need to tweak a little to reduce the body roll.. Very Happy
Huggable wrote:Excellent effort! Liked the welding of the handles, and the use of balloon base for the dashboard dials.
thanks bro... yeah, still thinking of whether to make the mirrors... will need one or two midnight oil session to solder up the m923 mirrors... still looking out for more detailed photos of the mirrors...
but my mind is thinking of the next build already... Very Happy
Post by RTECH on Thu 9 Aug 2012 - 20:15
bounce Wats your next build ?
Post by boolean21 on Fri 10 Aug 2012 - 23:25
RTECH wrote: bounce Wats your next build ?
Still in the planning stage.. Very Happy
Post by boolean21 on Fri 19 Oct 2012 - 23:56
just some minor updates...
the M923's 2pc extended drive shaft seems to be causing some binding problems.... so... decided to make it into one long piece....
chopped up some old axial drive shafts and extended the rear drive shaft....
will try it out soon... Smile
here's some photos....
Post by wyetuck88 on Sat 20 Oct 2012 - 0:20
Thats a super long shaft!!! Very Happy will the torque twist it out of shape?
Post by boolean21 on Sat 20 Oct 2012 - 0:27
wyetuck88 wrote:Thats a super long shaft!!! Very Happy will the torque twist it out of shape?
yeah, high chance it will....
just wanna try whether it is really the 2pc drive shaft causing the binding.... if really so... then will make a long drive shaft in metal..... or partly metal... Very Happy
