July 2018
Boolean21's 1/10 M923 - 5 ton truck - Newbie try to scratch build a truck body... :D
Page 3 of 6 Previous  1, 2, 3, 4, 5, 6  Next
Re: Boolean21's 1/10 M923 - 5 ton truck - Newbie try to scratch build a truck body... :D
Post by boolean21 on Thu 5 Jul 2012 - 23:55
mounted the ripsaws to do some photo comparison...
should be going ahead with ripsaws for the M923.... and keep the super swampers for my wraith... Smile
bought the hinges for the bed... will keep these aside for the time being...
mounted the ripsaws on the truck...
comparison between the ripsaw and the creeper tyres...
ripsaw - 5.5" tall
creeper - around 5" tall
more photos....
Tyre size comparison photo...
A comparison between the M923 on creeper tyres and on the ripsaws....
Post by wyetuck88 on Fri 6 Jul 2012 - 1:15
looking really good...hey Boo, how much you bought your tyres for? whats the width? I am not sure what tyres I am using and I am planning to change it. Its too thick for my body...
Post by boolean21 on Fri 6 Jul 2012 - 1:30
wyetuck88 wrote:looking really good...hey Boo, how much you bought your tyres for? whats the width? I am not sure what tyres I am using and I am planning to change it. Its too thick for my body...
thanks bro...
the ripsaws are from my wraith... Razz getting another 4 more pcs....
the ripsaws are around 5.5cm wide, and 5.5" tall.
Post by wyetuck88 on Fri 6 Jul 2012 - 1:36
oh icic I am looking for a narrow but 5.5 inch in height tires. Any model to recommend?
Post by boolean21 on Fri 6 Jul 2012 - 1:41
wyetuck88 wrote:oh icic I am looking for a narrow but 5.5 inch in height tires. Any model to recommend?
Hmmm... No idea... Will keep a lookout for you...
See if there rest have any tyres to recommend...
Post by boolean21 on Sat 7 Jul 2012 - 1:49
my new grill!!... inspired by LaneboysRC... the valueshop pencil holder...
my grill is bigger... so i bought the round pencil holder, cut up the top and bottom and i have a long piece of wire mesh... the mesh size is nice!
front grill now looks nicer. Smile thanks Laneboysrc.. Smile
primed the bed and the 3 bed sides... the wood seems to absorb all the paint.... took me 1+ can of nippon pylox flat white.... sprayed, sanded a little and sprayed again...
made the base plate for the 2 side boxes... and mock up the position...
fabbed some "S-bracket" to mount the side boxes... the idea is to let it "wobble" when the truck is moving... so styrene should do the job instead of 3mm aluminium bracket... hope the styrene will hold up well... Very Happy
mounted the side boxes up...
the bed, when the 3 bed sides flips open... can fit my honcho nicely...
this truck is small... compared to some one's secret project... Twisted Evil Twisted Evil Twisted Evil
Post by laneboysrc on Sat 7 Jul 2012 - 7:26
Looking good! Where did you get the small Honcho from Very Happy
How did you bend the Styrene? Hot water? Open flame? Hairdryer?
Post by boolean21 on Sat 7 Jul 2012 - 8:51
laneboysrc wrote:Looking good! Where did you get the small Honcho from Very Happy
Very Happy
I heated the styrene using a normal lighter.... Around 6 to 7 seconds of open flame on the bend lines make it easy to bend at sharp angles. Smile
Post by RTECH on Sat 7 Jul 2012 - 10:22
Shocked Swee! Master boo, wat color you intend to spray?
Post by boolean21 on Sat 7 Jul 2012 - 10:27
Thanks bro... Master is Liew...
Newbie Boo should be going for light sand color...
Now thinking whether to keep the wheel rings same as body color, black or the whole wheel spray same color as body....
Post by wyetuck88 on Sat 7 Jul 2012 - 12:11
nicely done!!! Very Happy
Post by boolean21 on Mon 9 Jul 2012 - 0:29
wyetuck88 wrote:nicely done!!! Very Happy
thanks bro. Smile
Post by boolean21 on Mon 9 Jul 2012 - 0:36
more updates...
dismantled the chassis for spraying...
found an old bumper base that i made for my landy... width is just nice for the base for m923 front bumper... Smile
made a simple dash panel, will print some sticker for the dials, etc...
took a spare steering wheel from the wraith spare parts lot and mocked up the driver... still got some more work to do on the interior and seats...
collect another set of 4 ripsaw tires today... now the tires are complete... Smile
the creeper foams are still nice and clean... as expected, no water and mud will get into the beadlock wheels... Smile
assembled the body and bed on the blackened chassis... didn't mount the axles and stuffs first cos i still need to blacken the links....
till the next midnight oil session.... Very Happy
Post by wyetuck88 on Mon 9 Jul 2012 - 0:45
Those midnight oils are definitely well spent...Looks wonderful!!!
Post by boolean21 on Mon 9 Jul 2012 - 0:51
wyetuck88 wrote:Those midnight oils are definitely well spent...Looks wonderful!!!
thanks for the kind words man. Smile
Post by RTECH on Mon 9 Jul 2012 - 19:48
bounce Can't wait to see the finish product.
Post by laneboysrc on Mon 9 Jul 2012 - 20:20
RTECH wrote: bounce Can't wait to see the finish product.
I second that! Very awesome project!
Post by boolean21 on Mon 9 Jul 2012 - 21:22
Thanks bros... Hope it turns out to look like truck... Very Happy
Post by boolean21 on Wed 11 Jul 2012 - 1:11
some updates...
sleeved the links with 8mm heat shrink... i think can use 7mm heat shrinks too...
photo is before heat shrinking... Very Happy
found some "materials" to make some dials on the dash....
and after the dremel-ing.... became these...
touched up the dials and "installed" them on the dash....
the M923 has some "handles" all around the truck... one handle on the bonnet, one handle on each side near the door, and one handle on the passenger side dash board...
i made some out of brass rods and brass strip...
after cutting and bending....
and after some soldering... the handles are done...
mounted up the axles back onto the chassis...
primed the handles with grey primer, will be priming the cab and bed again with the grey primer before the final coat of paint....
some photos of the handles mocked up on the different positions...
thats all for today's midnight oil....
need to top up some oil liao... Very Happy
Post by wyetuck88 on Wed 11 Jul 2012 - 1:31
nice work!!! need to burn more oil. Very Happy
Post by laneboysrc on Wed 11 Jul 2012 - 7:10
Excellent. Work on the details started.
Great idea with the instruments. Do you have a photo of real instruments? May be worth printing them, cutting them out and sticking inside the rings cat
Post by boolean21 on Wed 11 Jul 2012 - 13:50
wyetuck88 wrote:nice work!!! need to burn more oil. Very Happy
yeah... must top up oil to burn... Very Happy
laneboysrc wrote:Excellent. Work on the details started.
didn't manage to find the meters... but will print some meters and stick into the rings... Smile
didn't follow the exact numbers of dials though... this is the photo that i found for the dash view..
Post by laneboysrc on Wed 11 Jul 2012 - 15:50
boolean21 wrote:didn't manage to find the meters... but will print some meters and stick into the rings... Smile
Bonus points if you make them light up from behind lol!
Actually I was thinking of lighting them up on our Dingo -- but discarded the idea due to time constraints. (old already, so no more midnight oil geek)
Post by boolean21 on Wed 11 Jul 2012 - 16:19
haha, yeah, thought about lighting up the dials too, and make the steering wheel turn too cos i have lots of bonnet space to play with... Very Happy
still thinking whether to do it as this will be a mudding rig! Very Happy
if i have extra oil to burn... i will try to incorporate them into the build... Razz
Post by angmohkia on Wed 11 Jul 2012 - 16:56
Build build build... Laughing
angmohkia
Post by dwong on Wed 11 Jul 2012 - 17:37
Hi, Bro Boo
May I know how you solder the brass strip and rod? Where did you buy those brass materials? Can share some info?
dwong
Post by boolean21 on Wed 11 Jul 2012 - 17:50
dwong wrote:Hi, Bro Boo
Hi, I used a mormal soldering iron and some stronger solder. Smile
Brass rods can get from Teck Leong Metals, address is in the DIY section. Smile
Post by dwong on Wed 11 Jul 2012 - 18:54
Appreciated..... Laughing
dwong
Post by RTECH on Wed 11 Jul 2012 - 19:39
bounce Burn ! Burn ! Burn !
Post by Marpek on Fri 13 Jul 2012 - 20:37
Not done yet??
