In total there are 7 users online :: 0 Registered, 0 Hidden and 7 Guests :: 1 Bot
May 2018
Rock crawling at Little Guilin.
Post by RTECH on Tue 23 Aug 2011 - 20:17
Re: Rock crawling at Little Guilin.
Post by n4smw26 on Tue 23 Aug 2011 - 20:27
Nice.. My all time favorite crawling place- guilin..
The torque twist on that ax10 is insane.. Stock springs/shock work best at that set up IMHO..
Post by RTECH on Tue 23 Aug 2011 - 20:31
n4smw26 wrote:Nice.. My all time favorite crawling place- guilin..
Surprised Bro, how about droop inner spring setting? It is better compare to the normal outer spring setting for rock crawling?
Post by n4smw26 on Tue 23 Aug 2011 - 20:45
Not necessarily better bro. U lose that ground clearance if u run full droop. Then u may want to think about those vertical drops.. Although u may be able to get ard that pesky torque twist.. Personally I prefer running droop with neg squat in rear.. Can climb steep inclines without toppling back..
Post by RTECH on Tue 23 Aug 2011 - 20:47
n4smw26 wrote:Not necessarily better bro. U lose that ground clearance if u run full droop. Then u may want to think about those vertical drops.. Although u may be able to get ard that pesky torque twist.. Personally I prefer running droop with neg squat in rear.. Can climb steep inclines without toppling back..
Oh.. I see. Thanks for the advice bro, will try it out.
Post by n4smw26 on Tue 23 Aug 2011 - 20:52
Then again, what do I know bout rock crawling.. Still noob..
Set up, try.. Set up try.. X20.. Till I satisfied Razz
Post by RTECH on Tue 23 Aug 2011 - 21:00
Wink This is wat this forum is for. Share our ideas . cheers
