Lighting and indication?
Post by beanstalk on Fri 17 Aug 2012 - 20:07
look at the link below, is this a similar setup to the light and indicator system you guys use?
http://store.rc4wd.com/Scale-Lighting-System-Ver-2_p_2364.html
beanstalk
Re: Lighting and indication?
Post by slow on Fri 17 Aug 2012 - 20:25
Hi beanstalk
Most of us used this light unit : http://www.hobbyking.com/hobbyking/store/__19817__Hobbyking_Scale_Car_LED_Light_system.html
and this http://www.hobbyking.com/hobbyking/store/__19816__Hobbyking_Scale_Car_LED_Light_system_Advanced.html
It is much cheaper then what you saw...
Post by beanstalk on Sat 18 Aug 2012 - 7:22
Ok thanks, is the lighting system you linked me second, is that easy to program? to indicate, and it only comes with 2 yellow indicators, can you used the white LED behind a orange indicator?
beanstalk
Post by oceanic on Sat 18 Aug 2012 - 7:58
Its easy setup, just follow the instruction manual. U can use the white led on the signal indicator.
Post by beanstalk on Sun 19 Aug 2012 - 6:33
Yeah, thats what is was wondering, thanks bro Very Happy
beanstalk
