by CraftRC Thu 18 Oct 2018 - 18:09
October 2018
Beadlock Wheel made of what material?
Post by babyboy on Wed 22 Aug 2012 - 13:08
When it says beadlock wheel can I assume that it is not made of plastic? Or it can be metal and plastic?
Re: Beadlock Wheel made of what material?
Post by boolean21 on Wed 22 Aug 2012 - 13:21
They can be plastic wheels with plastic rings, plastic wheels with metal rings or metal wheels with metal rings.... Smile
Post by laneboysrc on Wed 22 Aug 2012 - 14:11
The one from Axial I bought for our Dingo are plastic wheels with metal rings.
2mm screws are used to bolt the rings to the wheel -- which is bad as they easily strip...
Post by babyboy on Wed 22 Aug 2012 - 14:46
Looking at purchashing 1.9 VR01 beadlock wheels for my second landy. Need to weight down the wheel more together with weights. Hmm if thats the case looks like it should be plastic. USD$11.20 for 2pc.
Thanks Guys!
Post by qks57 on Wed 31 Oct 2012 - 10:15
VR-01 beadlocks are plastic. the nuts and bolts rust very easily, recommended to get stainless nuts and bolts for it. Smile i used to have a set of them on my mini-trophy.
