TX Battery recommendation
Hi Guys. I want to replace my TX battery.(PCM Futaba TX) There's a lot of LiFe brand of battery. Looking at HK brand is only less than USD$10. Is this brand ok? Or there's a better brand to recommend or consider?
Re: TX Battery recommendation
Havent tried LiFe batteries... I think rtech is using LiFe. Wait for him to reply.
You bought a new charger?
I used Hobbyking nano-tech LiFe for my futaba 4PL, is faultless and only about $10. Make sure your charger can charge LiFe as they have lower voltage.
colgout- Crawler
I use the nano-tech 6.6v Life from HK. This is a new type of lipo that will not bloat that easily. Although the pack written for receiver but it is compatible with TX. Just make sure the dimmension can fit into your TX.
Dun use the eurgle 6.4v Life. Mine bloated and one cell damage.
I have the charger for the battery. At 6.6v my Tx will not work. Power off after 7.2v if I am not wrong. Beeping at 7.2v. Ok will get the HK battery. LHS that I went to out of stock. Thanks guys.
» [TIPS] Turnigy nano-tech 4200mAh battery for M-Chassis or nimh battery compartments
» SCX10 Shock recommendation please
» ESC recommendation required for full brake.
» 2.4Ghz radio system recommendation
» Battery connectors help
